Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-12-2012, 10:04 AM
Gasoline Gasoline is offline
Garage is empty, add now
Gasoline is starting off with a positive reputation.
1957 Ford Vanette help needed - Disc Brakes
Hi,
I have searched and searched and can't find the info I need. I need a mentor for my oddball truck.
I bought a 1957 Ford Vanette step van. It has 8X6.5" drum hubs. I would like to keep the front axle but go to disc brakes. I am guessing it (P35) is a 1 ton?
What are my disc brake options? Any?
Is it possible to change the pattern to sonething else? 5X5" etc?
Thanks in advance for any help!
Click the image to open in full size.
T
  #2 (permalink)
Old 07-12-2012, 02:57 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
This is a P Series Parcel Delivery, specifically a P350 since it has 8 lug wheels on a 6.50" bolt circle. P's commonly referred to as "bread trucks" because so many bakeries used them.
Were sold several ways: To RV dealers as a rolling chassis, mounted Class A Motor Home bodies.
To aftermarket body makers as a rolling chassis with front end sheet metal, dash, sliding doors, one seat (passenger seat optional). Nothing was behind the front seat except bare frame rails.
There are no aftermarket parts available. Most of the parts are obsolete, was cancelled after 1977, replaced by the E350 "Cut-Away" or E350 rolling chassis.
8 lug, 6.50" bolt circle: 1955/97 F250, 1967/97 F350 / 1969/74 E300 / 1975/2012 E250/350.
8 lug 6.50" bolt circle: 1968/72 F250 2WD's were available with optional dual piston caliper disc brakes, which became standard equipment in 1973.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 07-12-2012, 11:50 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
I have done a few different old straight axle conversions just using what I could find and a little ingenuity. Find a rotor from some tuck of similar size and do some measuring on the distance between the inner and outer bearing.. Most bearing places can come up bearings if given the inner and outer dimensions. Even better if your drum separates from the hub, then you may find a rotor to fit your existing hub. Once you have rotors, choose a suitable caliper and build the brackets.
this isn't the best picture but It's one of my "conversions". Axle was Econoline, rotors from a Ford Aerostar, homemade brackets and Chevy metric rotors. I could have used Crown Vic rotors but couldn't fit the 14 inch wheels I wanted to run. You get the idea.
  #4 (permalink)
Old 07-13-2012, 06:17 AM
Walston's Avatar
Walston Walston is online now
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
I would check with these guys: Engineered Components, Inc. - Your One Stop Brake Shop!
__________________
Walston
http://bigjohnstractor.com/
  #5 (permalink)
Old 07-14-2012, 09:01 AM
Thanks guys. I will keep you posted of my progress. Tom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
