building up the 410...
Old 07-19-2012, 11:52 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
All things considered, where can you get the power increase that kit will give you for $1000? The dollar-per-incremental HP scale is pretty steep, and that seems a "bargain"...maybe. ymmv.
Old 07-21-2012, 10:20 AM
410F-100's Avatar
410F-100
410F-100 is offline
now that i think about it that was a stupid question, if i go 445 then ill have a 1ub crank, the rods and pistons up for sale so somebody can make their very own 410...
gunna have to call survival and see what they recomend to go along w/ their 445.
then onto placing orders...
Old 07-21-2012, 11:38 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
You'll likely need a different flywheel/flexplate. The 410 used one with a counterweight, and I'm pretty sure the Survival 445 kit is fully balanced internally, so you'll need the flex/fly for a 390 without the weight on it.
Old 07-21-2012, 06:42 PM
410F-100's Avatar
410F-100
410F-100 is offline
i was sorta planning on a new flywheel too. might as well ya know.
i plan on replacing everything except for the block, unless i find a 428 block at a good price
Old 09-08-2012, 11:49 PM
410F-100's Avatar
410F-100
410F-100 is offline
soooo, iv been taking my time, and changing my mind time to time... but its gettin close to that time...
iv been eyeballing a decent 428 block for a while now, thinking greedily about the power a 465 would make...
its quite abit more convent to assemble a short block before i tear the truck apart since it is my daily driver.
gunna be crappy gas milage no matter the build so why not huh!!! may just have to give up my 4.11 gears
maby a roller cam too while im at it? good or bad idea for a daily driver and occasional off road adventure... or would a regular hydraulic cam be best?
there is nothing wrong w/ my 410 at the moment, so i have time to over build!
Old 09-09-2012, 01:36 AM
410F-100's Avatar
410F-100
410F-100 is offline
just curious, what dose a decent 428 block go for? not like ill find one close by before im ready.
Old 09-09-2012, 02:21 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
My .30 over 428 block alone cost me $900 and i had it shipped from 200 miles away
Old 11-10-2012, 09:07 AM
LedheadELH's Avatar
LedheadELH
LedheadELH is offline
Hell I ended up throwing away 3 360/390 blocks before I found one that was worthy of my 445 biuld. Paid $250 for the fourth one, thank god it was good after .030 over.
First one was too rusty, after .060 the rust was still bleeding through. Second one had a wrist pin that slid out, and put a HUGE gouge in one cylinder( kept that one though, may sleeve that cylinder for another build) The third one had broken piston rings on 2 cylinders, so a again huge 1/4" wide gouges.
When scrap prices went up, alot of nice old FE engines got crushed, so they are MUCH harder to find for cheap now
Old 04-13-2015, 11:53 PM
410F-100's Avatar
410F-100
410F-100 is offline
Well its been a few years, but Iv finally made up my mind, and ordered all the parts for a 416 mild(ish) build... Just got to save up a few more bones for some CNC work on the heads...
Maybe Ill have the motor built before the end of the year?!!
DJOHNSTON78
15
12-13-2007 08:49 AM
tastyklair
10-14-2004 02:59 AM
metallicafan
08-02-2003 12:13 AM
dhickey
10-18-2002 06:20 PM
otto
11-19-2001 08:52 AM
Quick Reply: building up the 410...
