Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 07-11-2012, 08:47 PM
Grandslam99 Grandslam99 is offline
2011 Ford F-250
Grandslam99 is starting off with a positive reputation.
6.2L Misfire cylinders 4 & 7
Has anyone had cylinder misfire codes and had a sucessfull repair. My 6.2L, 12,000 miles towing has experienced #4 & #7 misfires. It's build date was 8/2010 and falls within the parameters of TSB 10-25-7. According to the servicing Ford dealer the Tech has examined the Rockers/Cam shafts and states that they look okay. Coil packs were moved around and still only cylinders #4 & #7 are reporting misfires.
Any help guys? Raptor's also are listed as experiencing this issue.
Thanks.
  #2 (permalink)
Old 07-11-2012, 11:29 PM
fixnair's Avatar
fixnair fixnair is offline
Garage is empty, add now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
Switch sparkplugs, if still there switch injectors, if still there do a compresion test.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #3 (permalink)
Old 07-13-2012, 05:01 PM
2011 Ford F-250
Smile "It's Fixed??"
Just back from the Ford Dealer, NO check engine light. Here's the story as I understand it. No mechanical issues, ALL rockers and Cam's look good, coil over plug on #4 and #7 were replaced, no change. Ford Tech Hotline had Local Tech make the computer relearn the crank/cam shaft sensor position. This is what the paperwork called "Performed CKP Neutral profile correction."
This corrected some "bad learning" in the adaptive power section of the computer.
In the next week or so I'll re-attach the Boat and Trailer and see what happens when we are towing it above 4.5K on the Tach.
If it goes South again I'll report back on this thread.
Enjoy!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
