Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 07-11-2012, 03:34 PM
Dasher400's Avatar
Dasher400 Dasher400 is online now
Garage is empty, add now
Dasher400 is gaining momentum as a positive member of FTE.
400 cam timing
I have been reading all over this thread and many others about the EGR'd 400 and the retarded cam timing. I am replacing the water pump in the next few days and figured I might as well replace the original timing set.
I have deleted all the EGR non sense and want the cam dialed in correct for non EGR engines. The last time I did anything with a timing set was 10 years ago. At that time I just set the engine on TDC and aligned the dots on the cam and crank gear.
So what do I need to do to dial it in correctly?
Thanks!
  #2 (permalink)
Old 07-11-2012, 06:50 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.
You want to get it back at zero. You can either get a stock replacement chain and gears for a 1970 351 cleveland or get an aftermarket double roller chain and gears and set the crankshaft sprocket in the zero slot.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 07-11-2012, 07:31 PM
Dasher400's Avatar
Quote:
Originally Posted by mark a. View Post
You want to get at back at zero. You can either get a stock replacement chain and gears for a 1970 351 cleveland or get an aftermarket double roller chain and gears and set the crankshaft sprocket in the zero slot.
Thanks Mark! I will get one ordered!
  #4 (permalink)
Old 07-11-2012, 09:47 PM
J ballan's Avatar
J ballan J ballan is offline
2003 Ford F-150
My Garage
J ballan is starting off with a positive reputation.
I picked up a double roller from comp cams and it looks like good quality for a reasonable price.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
