Remove vacuum lines 1979 F100 351M
What vaccum lines/smog stuff can I remove that will not hurt my truck's performance and possibnly even make it run better? Are there any pics on this website that show step by step so I do not mess my truck up? I know this has been done, I just cannot find any pictures of what I need to leave in place and what needs to come out. I am not interested in the legal aspects of this. This truck is rarely driven and in GA it is old enough to not have to worry about.
Abraham
Abraham
Not running fine
The choke is messing up and after I drive about 10-15 miles the truck shuts off. About 5 mins later it will start right back up.
Fuel Filter is fine
At the front of the carb on the right (as you are looking at it) there is a round cyclinder infront of the linkage with a wire comming out of it, what is that for?
I wantd to remove the vaccum lines to rule them out.
Abraham
Fuel Filter is fine
Abraham
Fuel Filter is fine
Abraham
Fuel Filter is fine
Abraham
[/URL]
Removing the vacuum lines will only lead to more frustration.
Idle stop solenoid
As depicted in the picture (right front) that is what I was asking about. How do I know if it is working properly? What does it do?
I will replace all vacuum lines and leave in place as suggested. I will replace silver box located on left side (driver's side) of truck first and then coil.
Thank you very much
Thank you very much
Ok,, I will weigh in here,,,, I took ALL that crap off my 77 351Measly,, I have ported vac. going to dist.,,, had to turn the allen head on the input a bit to get better advance,,, have PCV and Brake booster and that is it,, put a 4bbl on it and it is a NEW engine,,, runs alot better,, no stumbling, gagging and running like a pig,,,, If you don't have smog,, take ALL that crap off,,, one vac. ported to dist. PCV and power brake booster,, you will be much happier!!
on
To test hold the throttle slightly open and put 12v power to the lead. If the rod pops out then it is functional. Normally it wouldn't have enough "grunt" to open the throttle by itself.
79250ranger
01-02-2015 12:58 PM
mcguyver
07-26-2002 05:20 PM
