How to clean and adjust a carb - Ford Truck Enthusiasts Forums
Old 07-11-2012, 01:21 PM
Fozzieb001's Avatar
Fozzieb001 Fozzieb001 is offline
Fozzieb001 is starting off with a positive reputation.
1970 Ford F250 Camper Special
Does anyone know or can provide a great resource or instructions on how to clean and adjust a carb?????
I have read post where people simple say to run a can of carb cleaner through it but did not provide and further information. Might you be able to provide this???
Carb adjustment - I have never adjusted a carb and would like to know how to properly adjust those two little screws for maximum effect.
THANKS!
Old 07-11-2012, 01:35 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Depending on how bad the carb is, just a spray of carb cleaner while it's running will get the gunk out of the venturis and hopefully clean up the air bleeds(where it draws air in on the sides). This sometimes helps a bit.
If the carb is in real bad shape, then disassembly and a real rebuild is in order.
Setting the idle mixture screws is relatively simple. Usually turn them in til they just bottom out(just touching). Then turn out 1 1/2 turns and start truck. Get it warmed up and idling smoothly. SLowly turn each one in til you hear the motor start to slow down. Go back out 1/4 turn. Do each screw separately.
In the end, both should be out the same amount of turns(roughly within 1/4-1/2 turn). You can use a vacuum guage to get more accurate and adjust for the most vacuum(which would be the highest idle speed). But in a pinch, listening will work.
Old 07-11-2012, 01:46 PM
Fozzieb001's Avatar
Thanks for the response!
Where in the carb will I spray?
Old 07-11-2012, 02:01 PM
Shiftoholic
As it's running, manually rev it up a bit and spray it right at the venturis(the holes in the middle). Usually once the cleaner gets into the engine it will falter so don't over do it. Give it a good shot and let motor come back up then repeat. You'll see what I mean.
Keep spraying around and you'll see the junk start to wash off. Likely you won't notice any great affects, but depends on condition.
Old 07-11-2012, 04:31 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
I fix and trade in a lot of gas powered things. Anything that has not been ran in a while, and especially if it was parked outside, needs the carb disassembled and cleaned. I find a lot of small engines have the needle varnished into the seat. Generally just a good sprat cleaner, I prefer Berryman's B12, sprayed through all the passages and blown down with air, and clean the obvious crud, put it back together and good to go. I don't even bother with a kit unless the gaskets are toast.
I also always run in any adjusting screws and count the number of turns, then remove so the passage can be blown out.
Old 07-11-2012, 10:38 PM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
If it's time you really want to learn something about these & your classic it's time to buy a manual so you'll have most of the answers right at hand. If your out on the road and it breaks down on you, you'll be more apt to get her going and Home with out a tow truck..A fairly good one is Ford Pick-Ups & Bronco many online stores sell them also..
orich
Old 07-12-2012, 01:40 AM
Manuals are good. I find any but the factory ones lacking. Don't even bother bringing home a Haynes from the parts store.
Old 07-12-2012, 09:21 AM
orich's Avatar
Quote:
Aw manuals are like women, they all have some little thing different about them. But enough info for the novices to get by who don't want to spring for a Ford truck shop manual tho.. my 2cents...
orich
Rancho RS9000 Shocks CollinsCD 1999 to 2016 Super Duty 6 07-07-2016 03:48 PM
What's and how's?? LandonAment 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 03-18-2016 12:10 PM
Adjusting an Edelbrock Carb. skipper Fuel Injection, Carburetion & Fuel System 23 05-01-2015 03:07 PM
Carburetor Adjustment jjurva 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-26-2011 09:06 PM
4 Barrel Carb Adjustment '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-11-2011 07:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
