Tune-up kit for a 46 Ford Flathead 6
The whole thing has to come out. I jacked mine up for a little extra clearance. It didn't fit into the cab and then out the door. Or I didn't have the room in my garage to do it that way. One or the other...
You have 2 bolts under the gauge cluster and then the 3 on the frame, plus the pitman arm. Not too hard just a pain.
Thanks i took mine out the bottom pull the steer wheel. Then unbolted the box from the frame took the bolts off the pitman arm and used a puller to get it off then pulled the whole thing out thru the bottom...the door screws where so attach had to use a blow torch to get the doors off, but that's an easy fix...thanks again
