new to WMO - Page 4 - Ford Truck Enthusiasts Forums
new to WMO
  #46
Old 02-01-2013, 01:33 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
well, i had nearly a full tank in there, and from the start i was sucking air. i haven't studied that bypass valve idea at all, and don't know if i even have one, but i do know that a number of the IDI guys have had problems with the pickup tube in the tank cracking and breaking, but they usually run out of fuel around 1/4 tank, mine would hardly run off that tank for the last week before i blew the engine, and like i said, i blamed the thick fuel because it was the only thing i had changed.
FWIW, i pulled out 22 gallons according to my eyeball estimate of 4 gallons at a time in a 5 gallon bucket, and i'm getting a ton more air in the line, but still getting fuel out of it. IIRC its a 22 gallon tank back there, so that means it was pretty darn well full while sucking air.
looks like i'll be dropping that tank far enough to get the sending unit out and see whats up inside there, and repair as needed. it sounds like the most likely scenario right now is that its cracked right below the flange that mounts it to the tank
  #47
Old 02-03-2013, 05:49 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
Do a search in the PSD or IDI section for the "Hutch" mod. I haven't had any problems with any of my pick-up tubes yet so I haven't done it but it sounds pretty easy and worth your time.
Diesel Rod
  #48
Old 02-03-2013, 08:38 PM
diesel rod, i just searched that, and found plenty of hits in the 99-up forum, and nothing for the IDI, so i suspect that doesn't apply to the IDI tank. i'll open it up and see, and i'll post back with the results
  #49
Old 02-04-2013, 06:47 PM
MNBen's Avatar
MNBen MNBen is offline
MNBen is starting off with a positive reputation.
A good write up for the Hutch mod ....
Welcome to guzzle's In-tank Hutch Mod Web Page
Also includes the harpoon mod within it.
  #50
Old 02-05-2013, 12:25 AM
thanks for the link. my pickup foot looks just like picture #9 in that thread - no screen or anything, and also no hose clamp holding it to the tube, it just stays there as a slip fit. i don't have the mixing chamber they're eliminating, so it appears that this mod does NOT apply to IDI powered trucks, but is for powerstrokes only.
i pulled it apart today trying to find a leak, and found everything perfect inside the tank. the metal lines in the tank are all free of leaks, pressure tested to 80PSI while under water.
so that leaves me back where i started, not knowing where my issue is coming from.
  #51
Old 03-03-2013, 01:04 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
Josh,,the timeing issue u had, Maby the temp sender that controls cold start advance, it kicks off at 110*,, I think..test your lift pump,,Iam assembaling my WMO set up, and will start burning soon hope to start small and build to 50/50,maby some RUG, if to thick, or smokey.
  #52
Old 03-03-2013, 01:21 AM
speedwrench, that temp sensor was only one of my problems, but it was one of them. there was also something up inside the IP that was screwing around.
after i got the whole rebuild of everything done after my head gasket failure, new ip, injectors, everything, i no longer have that timing issue.
my current position is that i'm running straight #2 for now, i have a bit of gunk in my rear tank which cost me about 6 pre-filters so far, with the current one running a good 10 miles before starving the engine, at which point i flip to the front tank for awhile, then back to the rear for another 10 miles before it starves again, and repeat. because its holding so steady now, i suspect the next pre-filter should last quite some time. during this process, my 2 micron water seperator/filter also plugged up, and i have it bypassed for now cause i haven't gotten a new filter for it yet. but outside of that i'm running great.
once i have my tank clean enough that i'm not running into issues, i'll start adding 1 gallon per tank of my WMO mix, which now has several gallons of diesel in the barrel, so it'll filter easier. i won't go stronger until i'm sure my filters are keeping crap out of my tank.
when i started running a strong mix like you're thinking is when i started getting gunk in my tank, probably due to a damaged filter before the fuel ever reached my tank, but remember that a general rule is that the greedier you get on WMO, the more likely you are to have a problem.
my wmo filter setup- your thoughts ta5150 Bio-diesel, Propane & Alternative Diesel Engine Fuels 80 11-17-2016 04:17 PM
WMO ideas? 10thMountainMechanic Bio-diesel, Propane & Alternative Diesel Engine Fuels 28 09-08-2014 06:27 PM
green gold filtering ? 86f350 Alternative Fuels, Hybrids & Mileage 3 09-10-2012 10:50 AM
why not syn? joshofalltrades Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 08-30-2012 12:56 PM
Newbie running wmo did i mess up?? boots6868 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 06-10-2012 08:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
