Thanks FTE! New Excursion, pics inside
I posted a couple months ago about getting a V-10 Excursion and here is what I ended up with, it's an 01' limited 4x4 with 102,000 miles. Got it from a Ford dealer so I paid a little more but it is super clean, they did the door lock actuators, front pinion seal, break pads, battery, all fluids, under coating and full detail as usual. The coils and fuel rails look very new aswell.
First things I have noticed, for a large truck it rips fairly good and has awsome throttle response. It drives straight and has none of the steering wheel movement or slop that can be an issue. The rear window lock always unlocks but is hit or miss on locking. It does need some different springs upfont as its low and speed bumps are harsh. This is my daily driver and my temporary tow rig, my last trip it was 17,100lbs and handled it ok except for the huge mountain grades, need taller gears to keep the speed, almost was dissapointed in the V-10's power on the big hills but I think the weight and gearing is too far apart for what I was doing. Air bags and onboard air is next for sure.
First mod was a 2 chamber flowmaster 3" inlet-dual 2.5" outlets, very happy with the sound as its nice and aggesive at higher revs but just cruising around its not too loud or anoying.
Second mod was the Tekonsha brake controller, best controller I have ever used and has very nice features. Well worth it.
Then I did the front headlights, I had these set aside for my superduty but they made there way the the Excursion and I think for a free mod its much better.
While I did the lights I did the front hitch, easy install and cheap too. Makes moving the trailer into tight spots that much easier, and I put my dirt bike rack on it too (although I need to make another rack cause its too dam tall!)
I wanted to have the use of the trailer brakes if I moved the trailer from the front, so I bought a 5th wheel 7-way extension kit for a superduty pickup, and cut it open and soldered and extended that another 10ft or so to reach the front of the truck. Now I can use both plugs at the same time if needed, I plan on adding some lights to my new bike rack to help out at night so this will come in handy for that aswell. Have yet to mount it in the truck as of now.
Overall very happy with the truck, thanks for the tips guys enjoy!
Like I said I am building a new rack for the front as yes it was sketchy to see around the bike!
V-10 Ford Excursion flowmaster 2 chamber exhaust - YouTube
The rack is overkill and would support the street bike but would be over the limit for the front hitch and would need to be used in the rear. The front is rated for 300lbs and when I bought it I was surprised at how beefy looking it was, but with my rack sticking so far out it has so much leverage, and the rack itself is 150lbs + 250lbs or more of bike it does flex the hitch more than I like. I am building an aluminum one dedicated for the front with a drop on it to lower the bike another 10-12 inches, also it will be way lighter and closer in to the hitch to reduce leverage and flex.
My travel trailer is 800lbs tongue weight and is way over its capacity but being used only for small maneuvers its just fine.
Anyone have any suggestions on must have or should or could have mods? Lets hear em'!
Nice set up!
How did you manage to install the front receiver using their supplied bolts? I had a tough time so I mounted them on the outside at first. Then I went and got OEM bolts and retainers to give it a factory look. Had to drill into the bumper for my license plate.
Here is mine.
I've changed my grille since then. Also have a Nomad trailer.
Here is mine.
I would not change it and love the sound, the muffler shop told me to return the muffler and that my wife would hate life in it but she likes it and doesnt complain. Also might help that the tips are right at the back bumper facing straight back, it is loud from outside but again not too bad inside.
Nice set up!
Here is mine.
Here is mine.
Here is what I made for my plate, I didnt want it to hang down too low and get in the way and its easy to remove, most people dont realize I have a hitch behind the plate.
Thats funny how big is your nomad? I have an 09' with 08' graffics and interior, when I ordered it they were changing the look so I had the choice of new or old and went with this.
