60 250 rear end
Old 07-09-2012, 05:05 PM
99hosss's Avatar
99hosss
99hosss is offline
60 250 rear end
Hey guys, I'm needing 2- 8 lug wheels for the 60 -250, which year trucks can I pick from in the scrap yard? thanks
Old 07-10-2012, 06:14 AM
3414's Avatar
3414
3414 is offline
Off the top of my head, up to 79.
Old 07-10-2012, 09:17 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Well beyond 1979.
8 lug, 6.50" bolt circle wheels (DRW not the same): 1957/97 F250 / 1967/97 F350 / 1969/74 E300 / 1975/2012 E250/350.
Econolines do not have metric wheels like 1998 thru today F250/350's have.
Old 07-10-2012, 02:21 PM
3414's Avatar
3414
3414 is offline
Went back and checked my notes, be careful with the 80s and 90s (up to 96) F250s. Some have larger diameter studs (they use the 1 1/16" across flats lug nuts) I do not know what year this started, so carefully look at the holes of the wheel. Although the bolt circle is the same, the rims have larger holes and the smaller lug nuts on the older trucks do not seat properly (too deep). I know from experience that the wheels from a 1990 F250 will fit over the studs on a 59 F250, but the lug nuts for the 1/2" studs engage the taper in the holes with the corners of the hex, not the taper. Not good.
Old 07-10-2012, 06:40 PM
99hosss's Avatar
99hosss
99hosss is offline
Thanks 3414/ND for yall's help- I appreciate the needed info- I don't want the wife takin a swing at me for seeing yet Another 250 wheel behind the garage- see you on the forum
Old 07-11-2012, 08:08 PM
Nick02's Avatar
Nick02
Nick02 is offline
Mine are off of a 1994 f250 2wd they fit my 8 lug axles and taper seems fine.
hjartland
04-18-2018 11:24 PM
fordtrucksforever
07-09-2015 05:14 AM
hondod
05-29-2012 03:55 AM
akrange
04-13-2003 09:33 PM
bob the viking
12-07-2002 06:28 AM
Quick Reply: 60 250 rear end
