Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-09-2012, 05:05 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
60 250 rear end
Hey guys, I'm needing 2- 8 lug wheels for the 60 -250, which year trucks can I pick from in the scrap yard? thanks
__________________
My addiction- wire brushing rust
  #2 (permalink)
Old 07-10-2012, 06:14 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
Off the top of my head, up to 79.
  #3 (permalink)
Old 07-10-2012, 09:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Well beyond 1979.
8 lug, 6.50" bolt circle wheels (DRW not the same): 1957/97 F250 / 1967/97 F350 / 1969/74 E300 / 1975/2012 E250/350.
Econolines do not have metric wheels like 1998 thru today F250/350's have.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 07-10-2012, 02:21 PM
1960 Ford F-600
My Garage
Went back and checked my notes, be careful with the 80s and 90s (up to 96) F250s. Some have larger diameter studs (they use the 1 1/16" across flats lug nuts) I do not know what year this started, so carefully look at the holes of the wheel. Although the bolt circle is the same, the rims have larger holes and the smaller lug nuts on the older trucks do not seat properly (too deep). I know from experience that the wheels from a 1990 F250 will fit over the studs on a 59 F250, but the lug nuts for the 1/2" studs engage the taper in the holes with the corners of the hex, not the taper. Not good.
  #5 (permalink)
Old 07-10-2012, 06:40 PM
1966 Ford F-250
Thanks 3414/ND for yall's help- I appreciate the needed info- I don't want the wife takin a swing at me for seeing yet Another 250 wheel behind the garage- see you on the forum
__________________
  #6 (permalink)
Old 07-11-2012, 08:08 PM
Nick02's Avatar
Nick02 Nick02 is offline
Garage is empty, add now
Nick02 is starting off with a positive reputation.
Mine are off of a 1994 f250 2wd they fit my 8 lug axles and taper seems fine.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
