are wheels spacers safe?
I guess it depends on what you are doing with it and how thick of spacer. I don't like them no matter what. They move the leverage point out and you rely on that little piece of aluminum to support everything. I know plenty of people use them all the time.
For "show" I would say okay. For towing/hauling I wouldn't. But that's me.
If you get a set cut correctly, maybe even including a hub ring, and you just use them to correctly space the mid-line of the wheel (as in putting 05+ wheels on 99-04 SDs), they're probably fine. If you're using them to space out the wheels really far, or to put on wheels that otherwise wouldn't fit, then probably not a good idea.
Highboy727678
04-13-2017 07:59 PM
senix
Fifth Wheel & Gooseneck RV Towing
08-27-2012 09:14 AM
