Rough Idle
Rough Idle
Does anyone associate the use of 10% Ethanol gasoline and rough idling? I just recently had idle issues and had the power valve replaced and a vacuum leak. I had those issues fixed and today it rough idled again. I sprayed some carb cleaner in the carb and the rough idle went away...I am wondering has anyone else had issues with varnishing or build up. I know these engines are not made for ethanol but ethanol free is few and far between. I didnt know if I just need to start using exclusively ethanol free gas unless im in a pinch.
Thanks
Thanks
To answer the OP, I haven't run into a problem, although some trucks are pickier than others.
82lightspruce
12-08-2017 10:20 AM
wekke
10-12-2014 11:05 AM
