1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wipers won't turn off
Old 07-08-2012, 08:37 PM
landgreen's Avatar
landgreen
landgreen is offline
Hello all. First off, this site is an amazing resource for repairing my trucks. Tech folder is in my favorites. Thanks for all the great info. I'm hoping this post may help someone out there with the same problem.
My 01 F-250's wipers would not shut off. As soon as the key was turned on they would come on. No delay but high and low only. Had to pull the fuse to drive it. I replaced the multi function switch as well as the relay with no fix. I did some reading on this problem and it is related to the "park" switch in the wiper motor itself. I took the black plastic cover off the motor which reveals the worm gear driving the plastic gear which acts as the switch. The contacts for this switch are hard to get to as they are on the backside. I blew compressed air into every little crevice and removed most of the grease. I regreased and put it back together. Sure enough the wipers work just fine now.
I am assuming the compressed air trick may be only temporary.Has anyone ever gone further to reveal the contacts for the park motor switch without destroying the plastic housing? Thanks for any input.
Old 05-13-2013, 04:07 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
I know this is an old thread, but did this solve your issue?
Old 05-13-2013, 04:40 PM
landgreen's Avatar
landgreen
Only temporary. They worked for a few more months then the motor died so replaced it.
Old 05-13-2013, 04:47 PM
ToMang07's Avatar
ToMang07
So it was the motor? And replacing the motor fixed it?
Elmo154
03-06-2016 06:12 PM
Grems4ever
18
11-02-2014 07:55 PM
ToMang07
06-17-2013 09:29 PM
pvine
11-19-2010 10:51 AM
3BadBirds
01-09-2007 12:42 PM
Quick Reply: Wipers won't turn off
