Wipers won't turn off - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2012, 08:37 PM
landgreen landgreen is offline
landgreen is starting off with a positive reputation.
Hello all. First off, this site is an amazing resource for repairing my trucks. Tech folder is in my favorites. Thanks for all the great info. I'm hoping this post may help someone out there with the same problem.
My 01 F-250's wipers would not shut off. As soon as the key was turned on they would come on. No delay but high and low only. Had to pull the fuse to drive it. I replaced the multi function switch as well as the relay with no fix. I did some reading on this problem and it is related to the "park" switch in the wiper motor itself. I took the black plastic cover off the motor which reveals the worm gear driving the plastic gear which acts as the switch. The contacts for this switch are hard to get to as they are on the backside. I blew compressed air into every little crevice and removed most of the grease. I regreased and put it back together. Sure enough the wipers work just fine now.
I am assuming the compressed air trick may be only temporary.Has anyone ever gone further to reveal the contacts for the park motor switch without destroying the plastic housing? Thanks for any input.
Old 05-13-2013, 04:07 PM
ToMang07's Avatar
ToMang07 ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
I know this is an old thread, but did this solve your issue?
Old 05-13-2013, 04:40 PM
Only temporary. They worked for a few more months then the motor died so replaced it.
Old 05-13-2013, 04:47 PM
ToMang07's Avatar
Quote:
So it was the motor? And replacing the motor fixed it?
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 10:22 PM
Rear wiper switch ('92-on): make it a momentary. asavage Aerostar 5 10-06-2015 01:46 AM
Intermittent Wipers & Wiper Wiring/Schematic granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-13-2013 05:48 PM
Wipers Stop...Then Restart...Then Stop... Tony_C 1961 - 1966 F-100 & Larger F-Series Trucks 12 09-10-2011 09:17 AM
Windshield wipers/washer psycho72 1987 - 1996 F150 & Larger F-Series Trucks 7 02-14-2010 07:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
