1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Are MPG between 6.8 and 6.2 a deciding factor?
Old 05-13-2013, 01:02 PM
Fastfwd's Avatar
Fastfwd
Fastfwd is offline
Let's say I am looking at used F250s and the price difference between a 2011 6.2 and a 2010 6.8 is 5000$
Should I factor in the price of gas too? I will be driving approximately 20k per year half empty and half with a travel trailer of 5th wheel.
MPG numbers are very fuzzy for the F250 but it seems like I can expect real world 12MPG for the 6.2 and 11MPG for the 6.8 in my scenario. So really not a big enough difference to factor in when choosing which to buy. Am I right? Am I wrong?
Also seems like there are no other big changes other than cosmetic between 2010 and 2011. Transmission sure but that factors into the engine MPG.. both can tow what I need easily. Anything I am missing there?
Old 05-13-2013, 02:17 PM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
It will depend more on how much the trailer weighs. The 6.8 will tow a heavier trailer better, and at a lower average RPM. The 6.2 should get better MPG when not towing than the 6.8 will.
I towed my trailer (6,500 lbs, 32 ft. bumper-pull) with both pickups, and liked the 6.8 better on the same hills, including a couple of 6 & 7% grades, about two miles long.
NOTE: Several posts on the 6.2 forum noted that the engine really "woke up" after 1,000 miles or so. I was driving a brand new unit, so my experience may have been a bit skewed!
I get 13.5-15.5 MPG on the highway, empty, with my '01 6.8. Most of my driving is done over 4,000 feet of elevation. I don't know of any real-world MPGs for a 6.2 around here, driven the same way. A friend who runs about 11,000 lbs all the time moved from a 6.8 to a 6.2 and is getting essentially the same mileage as he did with the 6.8, both about 11 MPG. That is the same as he got with a 5.4 and a 6.0 Chevy, too. He tends to run about 10 over the speed limit, I don't.
Old 05-13-2013, 03:24 PM
montey2005's Avatar
montey2005
montey2005 is offline
I have a spreadsheet you can use to calculate the difference. send me an email asking for the MPG calculation via pm with your personal email.
hendu4672
2017+ Super Duty
37
05-22-2023 06:01 AM
iggy2
6.2L V8
17
07-25-2015 12:02 AM
ctownson
6.7L Power Stroke Diesel
26
02-21-2011 03:32 AM
klifter
6.4L Power Stroke Diesel
16
07-15-2008 07:54 PM
Nighthawk
05-29-2004 06:33 AM
Quick Reply: Are MPG between 6.8 and 6.2 a deciding factor?
