1971 F250 4x4 hub caps
Old 05-09-2003, 02:20 AM
Faithful Old Road Dog's Avatar
Faithful Old Road Dog is offline
Hello members! I recently purchased a 1971 F250 4x4 and I know it doesn't have the correct hub caps. My search for "1971 hub caps 4x4" did not get the results I wanted. Can anyone show me pics of the correct hub caps I should be hunting for?
Old 05-09-2003, 09:05 PM
comet's Avatar
comet
comet is offline
That's a good question, I've often wondered that too. I saw one guy cut out the front caps for the hubs on the typical 2wd caps. Looked pretty good, could have even been stock for all I know.
Old 12-12-2003, 02:23 PM
oem78's Avatar
oem78
oem78 is offline
I've got a set on my 1978 4x4, don't know if ther stock or cut out , they look good. Picture are in the gallery, The front are like the backs, with a hole.
Old 12-12-2003, 02:47 PM
BB's Avatar
BB
BB is offline
Here's a closer view, don't know if the "hole" ones are stock, all the literature shows no caps on the front of the 4x4's
Old 12-12-2003, 02:52 PM
oem78's Avatar
oem78
oem78 is offline
I have those exact hub caps on my 1978 4x4. The front hub caps have a hole in the center for the manual hubs. Does anyone know if Ford made them this way.
Old 12-12-2003, 02:58 PM
BB's Avatar
BB
BB is offline
Well if Ford did it I would guess it would be a punched hole rather than a cut-out hole. Does it look like the hole in your hub caps were machine punched?
Barry
Old 12-12-2003, 03:26 PM
oem78's Avatar
oem78
oem78 is offline
Excellent point, I'll have to check them out when I get home tonight, never thought of looking at the edge of the hole, thanks for the idea,
Old 12-13-2003, 04:31 AM
71_4x4_390's Avatar
71_4x4_390
71_4x4_390 is offline
I don't think the 71 F250 4x4's came with hub caps, only the F100's. I too have the stock 2x4 caps with the holes drilled out of them on the front. We are a rare breed who like the stock look! All the brochures I've seen show the F250 4x4 without caps.
Old 12-13-2003, 05:18 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Check OEM's cross post in the 73-9 forum.
Old 12-13-2003, 09:34 AM
78f3504x4's Avatar
78f3504x4
78f3504x4 is offline
check my gallery, I have stockers on my 71. Not sure if the 1/2 tons and 3/4 tons used the same hubcaps, though.
Old 12-14-2003, 01:28 AM
78f3504x4, Those hub caps look like 15"s from the early Bronco's.
Old 12-14-2003, 04:21 AM
71_4x4_390's Avatar
71_4x4_390
Wouldn't you know it, this weekend I went out and beat the hell outta my truck 4 wheelin and crushed one of my caps! I got stuck in some thick mud, borrowed, or stole, a farmers mini bulldozer to pull it out. Then drove through a washed out road and crushed the cap, snapped of a valve stem. My Hi-Lift jack got jammed from all the mud and I crushed my ring finger changing the tire, breaking the bone on the tip when I pinched it between the jack and handle. DOH!! My truck is out of aliegnment, I bent the fender, dented passenger quarter panel and broke my finger. What a weekend! But I now know how to drive a bulldozer!!!!
Old 12-14-2003, 10:58 AM
78f3504x4's Avatar
78f3504x4
Yes, the F100s and the Broncos used the same hubcaps, the ones I have on my 71 are the originals.
logan454761
03-02-2017 12:50 PM
DerekShiekhi
02-27-2016 06:55 PM
Bigred1971
68
01-15-2016 07:43 PM
frncfish2
27
12-31-2015 09:47 AM
Teren
11-27-2010 09:25 AM
Quick Reply: 1971 F250 4x4 hub caps
