Ign Coil Tests...
Ign Coil Tests...
Hey all,
I've got my 72 f100 302 out of winter storage finally, and I am continuing my quest to get it purrring. Can you help me with any ideas on how to test the coil? It turns over, but it doesn't seem to get any juice to the plugs... the S.P. cables are all brand new.
Thanks in advance!.... glad to be elbow deep in engine dirt again.....
mike
mike
on
Ign Coil Tests...
You can meter the coil between the coil tower and the negative terminal should have continuity and maybe around 6000 to 9000 ohms or so and between the coil positive terminal and the coil negative terminal should also have continuity and around 10 ohms or less.
I am not really sure of the exact resistnace values depends on type of coil and how old it is. Nut you should have continuity both ways with the tower to negative being significantly higher in readings.
Have you checked your points to see if they are stuck closed or pitted/corroded ??? Or does the truck have electronic ignition like the Duraspark?
hogryder007
17
07-27-2016 04:54 PM
V8SHO
1997-2006 Expedition & Navigator
30
03-16-2016 10:10 PM
