A/C compressor conversion, York to Sanden - Ford Truck Enthusiasts Forums
Old 07-07-2012, 11:12 PM
beechkingd beechkingd is offline
beechkingd is starting off with a positive reputation.
There have been several threads over the years about doing this swap, but most of them went a little beyond what I was interested in doing. I had a functioning factory installed system with the York compressor on my 460 powered '79 F150.
Last summer the compressor failed and I became more interested in doing this swap. I was not interested in doing an R134a conversion because it would require a bigger condenser and new lines. R12 is available on Ebay and I have a good supply of it.
I was able to find all the components required to do the swap on Ebay for $200 shipped, which included.
1. 9285 SANDEN SD508 STYLE COMPRESSOR W/ CLUTCH
2. YORK TO SANDEN /SELTEC ADJUST. COMPRESSOR MOUNT KIT
3. MALE O RING TO FEMALE O RING #8 90 DEGREE ADAPTER FITTING
4. MALE O RING TO FEMALE O RING #10 90 DEGREE ADAPTER FITTING
(all of them came from FORD ELECTRICAL SWITCHES, MOTOR MOUNTS items in MR FOMOCO MOTORCRAFT store on eBay! who nicely combined the shipping costs)
I also locally purchased a new receiver dryer, longer V belt, some orings, and some longer bolts for the A/C mount bracket.
It was entirely bolt on except for cutting some spacers to locate the compressor in the mount. The original lines connected easily and the A/C is working great, even at idle with no vibration. The only minor annoyance is the high pressure service port on the compressor is a #3 flare fitting instead of the normal #4 size so I had to dig up an adapter for my gauge set.
Old 07-07-2012, 11:16 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
I like the look of the Sanden compressor and am thinking about doing the conversion, but I have a good working York right now, so I will keep that until I need a new one.
Old 07-08-2012, 01:49 AM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
Quote:
Anyone have the complete P/N's for new brackets and all, etc, to convert a york compresor to a Sanden on a 76 F250 with a 390? It seems to me, the york draws down on HP compared to modern compressors. I want to convert mine.
On another note..does anyone have a description/picture of the txv bulb location for a 77 F150?
Old 07-08-2012, 07:50 AM
Quote:
I would guess that all of the stuff I used would be the same, the hose sizes seemed to be standard sizes for compressors. Searching the descriptions I posted on ebay should take you there.
Old 04-01-2013, 01:17 AM
jbancroft jbancroft is offline
jbancroft is starting off with a positive reputation.
Hi, can you tell me:
1. what do you mean "cutting some spacers"?
2. why did you go with the SD5 instead of the SD7- my understanding is the SD7xx has more output, which you would want with a 460, or it that more related to cab space and the SD5XX works fine?
3. Did you keep the idler pulley? I notice something that looks like one under the compressor. i have a 76 460 & mine's up top to the left of the compressor
any help appreciated
thx.
Old 04-01-2013, 03:29 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
beechkingd thanks for posting this. I need to do the exact same thing. Gonna follow along.
Old 04-01-2013, 09:33 AM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Quote:
+1 on the post, thanks .. Your windshield washer reservoir needs some work
Old 04-01-2013, 10:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
I did the Sanden conversion too. The Sanden is lighter, quieter, and more efficient than the York. Plus, at least in my area, you can buy a new Sanden complete with clutch for less than a rebuilt York w/o clutch.
I had new hoses made also so I didn't use the adapter fittings.
I got my bracket from Nostalgic Air in Tampa, Fl. They make the bracket I used that allows the original tensioning setup to be used. They also make a bracket that allows the compressor to pivot to tighten the belt.
Aftermarket Air Conditioning For Automobiles and AC parts
Old 11-30-2014, 06:54 PM
Sam's1967 Sam's1967 is offline
Sam's1967 is starting off with a positive reputation.
I am about to do a similar conversion on my 67 F100. I bought a a kit from Mr. Fomoco as well. How's yours holding up? Any regrets? What size condensor did you purchase? Any fitment issues?
Old 11-30-2014, 09:26 PM
EP145's Avatar
EP145 EP145 is offline
EP145 is starting off with a positive reputation.
I used this one on my FE it looks a lot like the one in this post and worked really well. Downloads - www.vintageair.com
Old 05-02-2016, 10:33 PM
kegger66's Avatar
kegger66 kegger66 is offline
kegger66 is gaining momentum as a positive member of FTE.kegger66 is gaining momentum as a positive member of FTE.
I've been working on getting A/C back in my '78 F150 400 - I read a lot of the FTE articles and settled on the setup that Beechkingd got.
For my 400:
I installed it and found that the compressor pulley was 3/8" off center from the tension and crank pulley. Pisser was I had it adjusted as far out as it would go...I'm not a welder so I went with the bolt modification...
(note: In addition to the 3/8" to align the pulleys I moved it out about 1/2" as well as the front of the pulley was within 1/2" of the fan blade. (and added 3rd bolt not in pic).
I have the liquid line to replace and then I should be ready to charge and go!
Old 07-09-2016, 06:51 PM
BGF100 BGF100 is offline
BGF100 is starting off with a positive reputation.
Question Ford air compressor pulley - V belt
Hi,
does any body know where I can get a V belt pulley as apposed to the serpentine pulley I have on a compressor at the moment.
As I would like to use the compressor in an AC retrofit.
Thanks,
Old 07-09-2016, 06:59 PM
mikeo0o0o0's Avatar
Quote:
Originally Posted by BGF100 View Post
Hi,
Thanks,
I would get the model number of the compressor and call a shop that specializes in just auto A/C and see whats available.
Old 07-21-2016, 05:34 AM
Smile Bracket
Quote:
For my 400:
(Ford 351M V8 A C Sanden Conversion Kit with 9263 Sanden Style Compressor | eBay)
Did you make the bracket your self, do you have any dimensions.
I have to fit one to a V8 Cleveland that did not have a compressor to start with. How did you mount a pulley wheel? I bought a Sanden 508 too. Thanks,
Old 07-21-2016, 08:56 AM
kegger66's Avatar
I got the top bracket from the same place I got the Sanden, as you see in the thread It wasn't the correct dimensions and I had to offset it to make fit. There are places that have AC bracket pulley kits (Ford 351C Alternator and Power Steering Brackets).
Do you have the bottom AC Compressor bracket? I have an extra
On the tension pulley - I had to find and buy (on the FTE Forum / Ebay) the Pulley bracket that mounted to the front of the engine since mine was missing. (You can see it in the pics in the thread below)
btw: here's another part of my AC project - there was an additional bracket I had to make to tie it all together. http://www.ford-trucks.com/forums/14...0-w-400-a.html
Replacing a york style compressor. 46Whizzer 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-20-2015 11:36 AM
Dad's Air Conditioner Compressor Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 05-01-2014 01:30 PM
A/C fittings V10man 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-04-2013 10:57 PM
York to Sanden Conversion mikeo0o0o0 1973 - 1979 F-100 & Larger F-Series Trucks 22 06-28-2013 03:51 PM
Sanden compressor conversion C Holden 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-22-2011 05:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
