1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
03 Expedition Airbag code 25
Old 07-07-2012, 05:19 PM
Rajczak's Avatar
Rajczak
Rajczak is offline
I am getting an airbag code 25 on my wifes 03 Expedition. I have found that it may be a code for the canopy airbags. Would someone be able to verify this before I go in and check this out?
What size resistor would a person need to use to simulate a canopy airbag to verify if its in the wiring, or an issue with the airbag module itself?
Thanks in advance for any help I can get on this.
Old 07-07-2012, 07:17 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The RCM is mounted under the front passenger seat. It's pretty common for wires to get pulled or connectors to get unseated.
Disconnect the battery negative cable, wait at least one minute, then check those connectors looking for any pushed/pulled pins or wires.
Sorry, don't have the value for the air bag simulator resistors.
Old 07-08-2012, 12:39 PM
Rajczak's Avatar
Rajczak
Rajczak is offline
Thanks SHO89. I will check all the connections on the module. May I assume that the "25 code" has something to do with that module?
Old 07-08-2012, 02:15 PM
projectSHO89
That module controls everything related to the airbag system, including the circuits to fire all the airbags which, of course, includes the passenger side-curtain units.
Old 07-08-2012, 02:39 PM
5.4T's Avatar
5.4T
5.4T is offline
thats the last thing you want to happen driving down the highway @70mph
Old 07-09-2012, 05:46 AM
projectSHO89
Won't happen. Since the module detected a fault in the circuit, the circuit was disabled.
truckh
Escape & Escape Hybrid
04-29-2014 09:58 AM
audieoutdoors
05-01-2011 09:05 PM
KEVINS800
1983 - 2012 Ranger & B-Series
20
01-17-2005 12:02 PM
dccorspa
04-24-2004 06:48 PM
mighty_mouse
02-27-2003 09:37 AM
Quick Reply: 03 Expedition Airbag code 25
