thanks i will p b blaster the bolts now and do it tomorrow. I figure to clean with brake cleaner, seal it up good n tight, then refill with3 1/2 quarts of synthetic
90 lbs is way too much, in my opinion. I dont have a clue what the book says, but id bet its not that high. I would do 20 as Rodney said. Idk about the lock tite, but if you do make sure you use the stuff that is removeable with tools. I believe its the green stuff. Dont use red or blue.
Hope this helps a little lol. I need to redo mine since the spots in my driveway tell me i missed a spot with the RTV
...Idk about the lock tite, but if you do make sure you use the stuff that is removeable with tools. I believe its the green stuff. Dont use red or blue...
Blue is fairly easily removed by hand tools. I've done red before too but you have to really use some gorilla snot to get em out without heat. I like the blue.
