2002 F250 ac problems - Ford Truck Enthusiasts Forums
Old 07-07-2012, 11:14 AM
Camp250 Camp250 is offline
Camp250 is starting off with a positive reputation.
Hello,
Someone please provide ac compressor settings on the low and high side for 2002 F250 7.3. When it blows, it blows cold, but then some times shuts off and blows warm air. I can turn it off and back on and it will work for a little while, but seems to get warmer because the compressor seems to turn on and off which seems like an electrical problem. A buddy of mine recharged it a few months ago and it worked fine until yesterday. Is it turning on and off because the freon level is low? Can i fill the low and high side from only the low side hose? Thank you, Tommy
Old 07-07-2012, 11:21 AM
twg1966's Avatar
twg1966 twg1966 is offline
Trying to Gain Knowledge
twg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to all
Did you check the shim on I believe it is the clutch? This might be your problem. I actually took mine out and it is now blowing cold air again. I think Springerpop is the one with the instructions.
Old 07-07-2012, 12:22 PM
I will check - thank you. Do you happen to know the pressure settings for the high and low on the ac? Thank you.
Old 07-07-2012, 04:04 PM
twg1966's Avatar
Camp250, I don't have a clue about the pressures. I am sure someone might chime in on that one soon.
Old 07-07-2012, 04:10 PM
twg1966's Avatar
Old 07-07-2012, 05:06 PM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
FWIW,
I had to replace the fan clutch (engine fan) on my 02 in sig, it was not pulling enough air across the condenser, when the condenser gets warm it would quit cooling, it would work just fine going down the road, but once i would stop moving it would stop cooling, just one more thing thing to check.
Old 07-07-2012, 05:14 PM
jerryjust's Avatar
jerryjust jerryjust is offline
jerryjust is starting off with a positive reputation.
TWG 1966
GREAT SITE AND VERY GOOD INSTRUCTIONS!!!!!
JERRYJUST
Old 07-08-2012, 05:33 AM
Poolguy601 Poolguy601 is offline
Poolguy601 is gaining momentum as a positive member of FTE.
Quote:
Pressures are relevent to out side temps. Your low side switch shuts the compressor off at around 23 psi. Low freon wants to suck that side into a vacuum. But yesterday at 105 degrees I had a truck pulling low side at 30 psi and high side at 210 psi with the engine fan engaged.
Old 07-08-2012, 08:59 AM
Great - thank you! What if i have too much pressure currently (low side is about 45 at 100 degrees yesterday) High side is about 150. How do i release pressure? Thank you.
Old 07-08-2012, 01:27 PM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
do the shim fix.. it fixed my a/c! so easy.
Old 07-08-2012, 04:32 PM
I just pulled it out and replaced it with a thinner shim. I used the thinest shim I could find and it wasn't much different than the original shim. Is working for now. I am hoping there was not another shim inside on the shaft. If it warms up again, i will pull over and pop the hood and see if the compressor is turning. You guys were correct, very easy fix!! thank you!!
Old 07-08-2012, 05:37 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
You might even be able to remove the shim completely, which is what I just did with mine yesterday. What you want is an air gap of about 0.010" - 0.020" between the clutch plate and the pulley surface.
You can go as close as possible as long as the clutch is not always engaged, but to determine that gap spacing, you need to measure/set it on the coldest day of the year for wherever you'll be driving during the winter season so that you don't end up with complete contact at a time when you're not needing the A/C.
Old 07-08-2012, 07:41 PM
I will if this doesn't work. Thank you.
Old 07-08-2012, 08:07 PM
Use this chart
R134a Refrigerant Pressure Temperature Calculator
If the pressures are a little high. But the system is cooling and you are ok with it. Leave it alone. If it is blowing warm then you have to start looking for the problem.
Old 07-12-2012, 09:27 AM
spooky01's Avatar
spooky01 spooky01 is offline
spooky01 is starting off with a positive reputation.
Can someone post the link for the shim mod mentioned earlier, and what the advantages of doing it are???? Thanks
AC system pressures Dirtscooter250 1999 - 2003 7.3L Power Stroke Diesel 10 06-09-2016 09:13 PM
1990 F250 AC kicks in and out Steve Cooling, Heating, Ventilation & A/C 5 05-16-2016 05:46 AM
05 F250 A/c problem superdutyMitchell 1999 to 2016 Super Duty 3 08-09-2015 12:06 PM
A/C blowing warm air tidexp 1999 - 2003 7.3L Power Stroke Diesel 24 07-08-2012 08:23 AM
F250 AC Compressor not Cycling VA250SD 1999 to 2016 Super Duty 3 08-09-2011 12:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
