Extended oil changes...
How long is everyone going between oil changes?? The dealer did the first oil change in my truck at 3k, I did it again at 8k and now at 15k. I took a sample and sent it in to Blackstone labs this time. I use Rotella T6 5w-40. Just wondering how many of you go beyond the 5k mark. Does anyone go 10k on an oil change?
oil life
I have learned that changing the oil is very important for the life and health of the engine. Whether it is the ATV or any 4 stroke or any vehicle. The question you ask is when to change without doing it too early and paying extra bucks? I have been changing mine at 10,000 kms, which is 6,200 miles, and before the message centre lets me know time for a change. Using quality oil and filter, keeping the oil changes consistent, help give me piece of mind. Of course many factors affect when an oil change is required. Driving conditions (the way you drive, towing, and the climate, etc., may all affect the interval. With the oil monitoring system it will remind you it is time to get the oil changed. I would have liked to see the oil system they use in some other vehicles in my F-250 where it will let you know by percentage how much oil life you have left or what percentage you have used up. (80% used for example) Keep the oil clean, use quality products, and that will go a long way in the life of your engine and your piece of mind.
Sam
Received 1,446 Likes
on
I wouldn't go with a 10k mile OCI without a UOA to get me there. Even if the OLM system said I could 10k miles.
If you want to go that far I would extend my OCI 2k miles every oil change and get a UOA every time to tell you how far you can go.
The major contributors to consider when extending your OCI is:
1. Wear Metals
2. TBN level
3. Fuel %
4. Viscosity
1. Wear Metals
2. TBN level
3. Fuel %
4. Viscosity
Changing oil every 3 to 5K miles is a waste of money on modern motors and modern oil and modern filters. The oil life monitor (OLM) is engineered to tell us when we should change oil. For me, average miles per the OLM has been ~8.5K.
Realistically, Ford warranties these motors for 100K miles, and that is using the OLM. They are not going to go out on a limb and risk replacing these motors by telling us to use the OLM!
Save some $$, use the OLM and change when it notifies you.
JMHO!
jammer
JMHO!
jammer
If you idle your truck for long periods, drive in town and never get the engine fully up to temp and things like that your oil should be changed more often. Maybe the truck will tell you sooner, maybe not. Far as I know the only things taken into account for the OLM is miles, engine hours, idle hours.
It doesn't have a 'sensor' that actually checks the oil for build up of wear metals or fuel dilution. It only makes a calculation based on the above mentioned parameters. The truck has no idea how much fuel dilution is present (there will always be some, more if you idle alot and/or don't get it hot often).
I'm not attempting to tell anyone what to do with their truck but for me, oil changes are one of the CHEAPEST things you can do to prolong the life of an engine. No way would I go 8-10k on the same oil, modern oil or not. Too much unnecessary engine/bearing wear to save less than $100 for me.
The other issue I have with the OLM is the truck has no idea what oil is in the engine. It doesn't know if it's a 'top of the line' synthetic or cheapo 10w30 from wal-mart. There has to be a fairly significant difference between those 2 oils but the truck doesn't that into account.
Just my .02
