cv front clip
Old 07-06-2012, 09:42 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
cv front clip
Hey Guys, After reading the threads on installing these clips I was wondering if anyone has mounted one but kept the ride height close to or just 1" to 2 " lower. I am going to go to a Coyote crate engine and set it up like my 67 XL but with an automatic. It has been gathering dust in the garage for the last 4 years. Time to re-restore my 68.
Kenny Nunez
Old 07-06-2012, 11:32 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
Kenny Nunez
You will have to space it up (add to the bottom of your rail).
Old 07-08-2012, 10:05 PM
Blue Oval Farm Boy's Avatar
Blue Oval Farm Boy
Blue Oval Farm Boy is offline
When I install my CV crossmember I was thinking about cutting a section out of the bottom frame rail, approx. 2 - 4 inches, kinda like a C notch would be for the rear axle/frame clearance, and then adding the same amount to the top of the frame to still bolt it in as the factory intended. This should get me 2-4" lower which is what I want as I want this truck to be lowww. The frame will be boxed and braced accordingly. I then still have the option of using lowering springs if I should want to go even lower. I don't know if anyone has tried this yet but I plan to in 6-8 months.
David.
Old 07-09-2012, 06:01 AM
elgemcdlf's Avatar
elgemcdlf
David.
I have not looked seriously at this option. The main problem you are going to run into is the rear mount for the lower control arm. It lines up right under the front cab mount. If air is an option for you they do make shocks with bags around them that can be used. I have only seen 1 truck with them. It was a crew cab & I do not remember the manufacturer.
Old 07-09-2012, 09:29 AM
Blue Oval Farm Boy
Originally Posted by elgemcdlf
The main problem you are going to run into is the rear mount for the lower control arm. It lines up right under the front cab mount. .
Ah, yes, I can see where that may take a little playing with, but hey, just one more hurdle to clear. I still have a bit of time before I get started so will keep the thinking cap on tight
David.
Old 07-09-2012, 08:39 PM
0ne_sik_70SWB's Avatar
0ne_sik_70SWB
0ne_sik_70SWB is offline
David.
you could always fab up a lower control arm i was thinking about doing it with a bag cup built in
oldmanrvr5
15
11-25-2012 09:24 AM
goodwrench
1983 - 2012 Ranger & B-Series
10-30-2007 07:55 AM
Gary E
12-14-2006 01:43 PM
mark-in-wyoming
06-20-2006 01:28 PM
AmeriKen
04-10-2006 05:44 PM
Quick Reply: cv front clip
