Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 07-06-2012, 10:09 AM
1999EBEXP 1999EBEXP is offline
Garage is empty, add now
1999EBEXP is starting off with a positive reputation.
Stuttering, Hesitation, Jerking, Shaking Problems When Accelerating
Hi All,
So I have a 1999 Ford EXP Eddie Bauer 5.4L. I start noticing the problem couple months back. Since I don't drive it that much because we own another vehicle, I thought it was just the cold winter causing the issues.
When the problem first started, it would jerk, shake or hesitate when it gets to about 55km/h. The only way to stop the hesitation is by forcing it to accelerate (by stepping on the gas pedal) until the RPM increases, then release gas. Once I've given it enough, it stops. While it's jerking, I also noticed that RPM is stuck to 2000rpm then it just jumps up rather than move gradually.
I've searched couple forums and it seems, for most people that are having similar problem, the culprit is/are bad coils or spark plugs. So I decided to bring it in and get it checked out by 2 mechanics. The surprise is both of them found something else and no mention of bad coils or plugs.
According to the first mechanic (Speedy Auto): Did a test. No code. Mechanic said its engine problem. Low compression rate on 2 cylinders. might be a leak on the head gasket or crack. Big $$$ to fix. He said it's probably not worth it to get fix considering the year of the car and its value.
Second Mechanic: Transmission slippage and bunch of other stuff not relating to the main issue. Said the same thing-Big $$$ to fix and not worth getting fix.
What do you think about my issue? I was thinking of bringing it in to another mechanic for a third opinion but I'm a little hesitant. Or maybe bring it in and just get the coils & plugs replaced and see if it fixes the issue? Each of these checks are causing me at least $100 each time. With so much stuff going on, I'm not really up there financially.
Please HELP.
  #2 (permalink)
Old 07-06-2012, 12:50 PM
5.4T's Avatar
5.4T 5.4T is offline
2002 Lincoln Navigator
5.4T has a good reputation on FTE.5.4T has a good reputation on FTE.
have you checked the pvc valve?
__________________
  #3 (permalink)
Old 07-06-2012, 08:04 PM
losymis losymis is offline
losymis is starting off with a positive reputation.
yea.^^^ That little elbow way in the back, that solved my same issue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
