Advantage to Moving Wheel Forward
Keep in mind once you move the spring lowered and forward you have to change out the draglink too. I missed that little bit on my 55 when I changed out the springs a few years back (before I know about FTE) and had to pony up more $$$. I love the springs but honestly I think it rides a little squishier now.
I would say from personal experience if you have to change to new springs, then go from the forwarding springs. I had to change my springs out in the 55 so it solved 2 issues, stance and forward. I wouldn't change out good springs just for the weight distribution factor.
I haven't heard of any advantages besides how much better it makes the truck look....and I will have to say, when it comes to things I "want" it's at the top of my list!
On the same note, who is it that makes the springs? I know mid fifty sells the "down and forward" springs, and I think I've heard of other companies selling them...
Bottom line is, anybody know who sells the cheapest lowering spring pack that moves the wheel forward? I'm sure BigDaddy and I would love to know...
At this point, I'm not sure that the springs need to be replaced If they did, I would go with moving the axle.
I'm just trying to figure out if I want to spend the money (which includes the installation since I cannot do it) for something that just makes the truck look better -- albeit, much, much better.
Thanks for the info!
However, don't you think the Ford engineers would have slightly redesigned the front fender opening radius?
Funny thing is on the panel the axle lines up with the center of the wheel arch.
If you are changing the springs anyways and if you want to lower the front end as well as softening the ride, the "forward" springs are not significantly different in price try Mid Fifty: www.midfiifty.com . The only other increased expense required is the extended drag link, and your OEM drag link probably needs rebuilding anyways. Replacing the front springs is about as simple a job as you'll find on the truck. Do you not have any mechanical skills or interest? Out of curiosity why would you buy a truck that requires work then, since hiring others to do any/all work will make ownership very expensive and you are already concerned about a relatively minimal extra expense? If you are paying to have your springs replaced, I would suggest you have the kingpins checked/replaced if they haven't been done recently, and replace the tie rod and ends with the HD one Mid Fifty sells while it's apart and before having it re-aligned, it will be a lot less expensive to have done all at once.
There shouldn't be any significant difference in time required.
I always wanted to learn how to work on cars, but my father felt it wasn't necessary since all "cars would be run by computers and have modular components in the future." That explains the lack of technical know how.
Add to that the fact that I am 44 years old with stage 4 esophageal cancer and you can understand why I have to have the work done by someone else. The irony here is that prior to my battle, I was over 400 lbs. -- too fat to work on the truck even though I had the money then. Now I am down to 215 lbs. and due to the major loss of muscle mass (and bank account) and the cancer, I am in too poor of health to do any significant work. Hell, I can only polish one mag a day since I get tired so easily.
I was told in January that I have six months to a year to live which is why I am in such a hurry. I want to get this truck back on the road so I can drive it around and enjoy it while I still have time.
Thanks for the information you've provided AX, I do appreciate your expertise. Since the truck only has around 16,000 original miles on it, I'll probably pass on the low and forward springs if the stock springs are fine.
