Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-05-2012, 11:56 PM
fixnair's Avatar
fixnair fixnair is offline
Garage is empty, add now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
Uh-Oh!
I am in the middle of building my Flathead V8 and am planning on doing away with the stock fuel pump. I wanted to plug off the guide for the pushrod. I was planning on using 5/16" cup type freeze plugs. I drove the first one down from the top and it was a somewhat tight fit. But as I drove it further down the hole it became looser the further I went. I was afraid it wasn't tight enough to withstand oil pressure. I had no recourse but drive it through the other end. Well I thought I could get it out from the cam area but I guess not.
My question is, do I have to remove the valves and cam to extract this little item? Would it cause any harm should I leave it there? It is a short block now with the crank, pistons, rods, cam & valves in.
Any help would be appreciated.
Thanks
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #2 (permalink)
Old 07-06-2012, 10:40 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
If you want it out, yeah, you'll need to remove all that you stated, but I can't see where it would hurt anything leaving it there. Its between the rear cam bearings, there would be oil around it so no dry metal running on dry metal. The only thing it would be touching is the push rod escentric. Looking at a flatty here in the shop, thats my observation, but experianced flathead guys may come up with that being a no no.
  #3 (permalink)
Old 07-06-2012, 11:36 PM
fixnair's Avatar
fixnair
Do you think it will eventually migrate down into the oil pan? If it gets down there it shouldn't cause any harm.
Thanks for the reply
__________________
2008 Lincoln MKX
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
