Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 07-05-2012, 10:42 PM
3Nails 3Nails is offline
Garage is empty, add now
3Nails is starting off with a positive reputation.
Roof top carrier - '99 F350 crewcab
Been looking for a roof top carrier for a '99 F350 crew cab. Prefer the basic two rail type. Do not want the kind with a strap that runs inside the cab to hold the rails in place. Everything I have found on the net requires a rain gutter to clamp to or has the inside strap. Will be carrying two 10' kayaks (40 lbs. and 44 lbs.). Anybody have any good solutions? Thanks for your help.
  #2 (permalink)
Old 07-09-2012, 09:28 AM
89LX306 89LX306 is offline
89LX306 is gaining momentum as a positive member of FTE.89LX306 is gaining momentum as a positive member of FTE.
I use Thule top track. I have it on the roof of my truck and my camper shell. I use their feet, bars, track and t-post.
Click the image to open in full size.
__________________
2012 F350 6.7 CC 4x4 - Stock and lovin' it, B&W OEM Companion
2002 F250 7.3 CC 4x4 - SOLD
  #3 (permalink)
Old 07-09-2012, 11:02 AM
JKBrad's Avatar
JKBrad JKBrad is offline
JKBrad is gaining momentum as a positive member of FTE.
This company makes a kayak carrier that is part of the headache rack. I've seen him hauling kayaks on it, seems to work very well.
Gallery - South Texas Outfitters - San Antonio's Premier Truck Accessory & Top Drive Manufacturer
__________________
2008 F250 Lariat Crew Cab, 4x4, V10, Torqshift, 4.30 axles
http://www.ford-trucks.com/user_gall...&albumid=28250
  #4 (permalink)
Old 07-09-2012, 06:44 PM
Thanks for the ideas. I had looked at the headache rack option, but didn't want something quite that permanent. I will be towing a fifth wheel so I'm pretty limited as to what will work. I think the rail system will work if I can find one that doesn't require gutters. I will check out the Thule rack system. Again....thanks....
  #5 (permalink)
Old 07-10-2012, 07:07 AM
Smokeispower's Avatar
Smokeispower Smokeispower is offline
Smokeispower is starting off with a positive reputation.
Can you put the kayaks in the 5th wheel? A lot easier and safer too. But I guess you still need a place for them when you get to your destination. Kinda scary strapping them on to the roof.
  #6 (permalink)
Old 07-10-2012, 07:28 AM
Not sure why my pictures won't show up. I'll try again. Those are enlargable thumbnails. As you can see we carry our kayaks with a 5th wheel as well. they are 14' Malibu X-factors. It has worked fine so far. I chose this system because it looks factory when the feet are removed and the rails are all that is left. It also allows me to use the same feet and wide bars on our Expedition with the factory rails.
__________________
  #7 (permalink)
Old 07-10-2012, 08:10 AM
We've stored the kayaks inside the fifth wheel, but it gets old taking them in and out when taking long trips and changing locations every other day. I like your set up 89LX306. Are the rails factory on your truck? If not, how do the rails attach to the cab. Are they permanent? Do you know the model number for the feet and rail system? Thanks...the pictures are great.
  #8 (permalink)
Old 07-10-2012, 09:04 AM
Quote:
These are the tracks and they are permanently mounted. They sit up maybe 1/2"-3/4" above the roof. They look factory and on my lifted truck are not even hardly visible. I didn't want something permanent if it didn't at least look factory, so I tried it on my camper shell first. I liked it so much, I also used it on my roof. There are different lengths and models of the top track. One uses bolts/nuts the other uses flare nuts. My truck roof has flare nuts, camper shell has bolts/nuts. Both have worked fine.
Thule*-*TP54 54" Tracks with Flare-Nut fastners
Thule*-*TB60 60" Tracks with bolts
This link shows the bars, feet and tracker kit. These are all removable from the top tracks and what I also use on my Expedition.
Thule Car Racks - 2012 Thule 430 Tracker II Complete Roof Racks
I use the goalpost on a front mounted hitch.
Thule*-*997 Goalpost
It all works great. I've carried the kayaks just on the camper shell and I've carried them on the roof like in the picture. No issues either way. Hope this helps a little bit.
__________________
  #9 (permalink)
Old 07-10-2012, 09:14 AM
Great!!! Exactly what I needed.....Will check them out. Thanks for the help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
