Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-05-2012, 10:00 PM
shamarbla shamarbla is offline
Garage is empty, add now
shamarbla is starting off with a positive reputation.
Shannon Blackwell
banks otto mind
Hi all,
Hope everyone had a safe and happy 4th.
I have a question.
On my pcm there is a
Banks Ottomind
Engine Calibration Module
Powerpack 62804
What is it, i went to banks and couldn't find it'
The reason for asking is I've had some pcm codes
and could this be part of the problem
Thanks
Shannon
  #2 (permalink)
Old 07-05-2012, 11:34 PM
1dieselman's Avatar
1dieselman 1dieselman is offline
1997 Ford F-250
1dieselman is starting off with a positive reputation.
They still have the Ottomind listed, it appears though that they have dropped most all their older engine listings. Almost every truck that I have scanned that had a chip or programmer installed would show a code or two but they where not detrimental to how it ran.
__________________
Jack
97 F250 XLT CCSB 4x4 PSD, H.D. E4od, fast spool 1.0 turbo, High pressure X line, 140v Idm, deleted ebpv, 6637 filter, 203* t-stat, 60hp Superchip, Isspro Ev gauges, Intercooled, 3"dp 4" shorty exhaust, 4" lift, 4:10 gears, 35" tires, 310,000 miles
  #3 (permalink)
Old 07-06-2012, 04:45 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.
Is the chip taped in to the pcm or is it loose at all?
__________________
Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,3.55-4.10 swap done,156k,140VIDM,HPX, 3-4"tymar w 4"straight pipe,ccv mod, S366 turbo, DIY 6637, elec. fuel,rosewood stage ones,php tunes,T500 HPOP,180 tstat,6.0 fan,6.0IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and triple disc billet converter, upgraded trans, F550 leaf springs,mean green alternator and starter,SD dual tensioner upgrade, cold ac mod
  #4 (permalink)
Old 07-06-2012, 07:25 AM
Shannon Blackwell
It was and is taped tight, I had to untape it to see what it was.
thanks for the information
Shannon
  #5 (permalink)
Old 07-06-2012, 01:00 PM
If you mess with it, make sure your keys are NOT in the ignition. If you are having problems, like a pcm code, take it out and see how it works.
__________________
  #6 (permalink)
Old 07-09-2012, 01:20 AM
Shannon Blackwell
Hope everyone had a great weekend.
Sorry I'm so slow about getting back.
Thanks for the warning about the keys in the ignition, i wasn't sure
so in undid the neg. battery cables also.
I've had my truck to 2 repair shops Ford and Earth Movers, and they both said either flash the pcm or get a new one.
It never has the same codes twice, except P0605
I'm gonna call DP Tuner in the morning.
I will try it without the chip, before i call.
Don't have the fender well popped back in yet so will be easy to put in and take back out.
OH, the truck is
1995 F350, 7.3, auto, 4x4, 4 door, lifted, Flat bed, 226,00 miles
SURE COULDN'T HAVE GOT THIS FAR WITHOUT YOU!
Even tho she's not running right now. She might in the morning, one just never knows
Thanks again to all,
Shannon
  #7 (permalink)
Old 07-09-2012, 04:42 AM
Good luck Shannon. Let us know how it goes.
__________________
  #8 (permalink)
Old 07-09-2012, 07:51 AM
Shannon Blackwell
Wink
Yes I will let you know how it turns out.
I have a good feeling, don't know if that counts for any thing.
but any way.
Thank you all so much
Shannon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
