Front end knocks when truck rocked. - Ford Truck Enthusiasts Forums
Old 07-05-2012, 07:24 PM
02transam 02transam is offline
02transam is gaining momentum as a positive member of FTE.
Please Help!
I have a 2005 F150 FX4 w/the 5.4 motor. I have been noticing a knocking noise when i go over bumps but can't figure it out. The same noise occurs when I grab the top of the front right or left wheel and push in and out. The truck will rock back and forth and this re-creates the noise. For some reason the noise sounds like it is coming from the engine bay area. Any help would be greatly appreciated. I can also get a video of it if you would like.
Thanks in advance!
Morgan
Old 07-05-2012, 07:35 PM
FORD COASTIE's Avatar
FORD COASTIE FORD COASTIE is offline
FORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to all
It sounds like your front swaybar links are worn out. This happened on my old 2004 at 82,000 miles. I had them replaced and the noise went away.
Old 07-05-2012, 07:47 PM
Quote:
Is there a way to ck the sway bar links?
Old 07-05-2012, 08:08 PM
I'm not sure what my mechanic did to check them. Maybe someone else will chime in that has more knowledge about it than me. I do remember that the swaybar links were very cheap. Good luck!
Old 07-05-2012, 08:12 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
You should be able to tell just by visually checking the links, maybe a slight tug on then if necessary
Old 07-05-2012, 09:35 PM
I checked them and there was no play in the lins.. I felt no play in any suspension parts. Like I said before it sounds almost like the sound is coming through the fender wells. I can push up and down on the suspension and no knows. I only get the knock when I am rocking the truck from left to right via the wheels.
Old 07-06-2012, 01:28 PM
daily bump.
Old 07-07-2012, 08:32 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
A few people have reported broken coil springs on the front. The breaks were near the bottom of the coil where they flatten out into the spring seats.
Old 07-07-2012, 02:34 PM
checked the coils and they are fine. I also noticed if i have my wheels turned I can rock the truck with no noise. The noise only occurs if the wheels are straight..... This is driving me crazy. Nobody can seem to figure out where the noise is coming from.. :-(
Old 07-07-2012, 02:42 PM
Here is a video of the noise. It is actually making two different types of noises now. One has a deeper sound and the other has a more metalic sound.
05 f150 suspension noise - YouTube
Old 07-07-2012, 03:31 PM
Mine only made one noise when I had the problem. It also took a few months and more than one mechanic to find the problem.
Old 07-07-2012, 04:12 PM
hcbph hcbph is offline
hcbph is starting off with a positive reputation.
Noise
I don't know your cause but I do have a suggestion. If you can create the noise sitting still, have someone do the movements while you're underneath. You may be able to track it down that way.
Good luck
Old 07-08-2012, 08:25 PM
I guess I am just going to start replacing parts starting with the least expensive.... Going to put on new sway bar links and bushings this wk.... This should be fun :-(.
Old 07-10-2012, 04:24 PM
robertc1216's Avatar
robertc1216 robertc1216 is offline
robertc1216 is starting off with a positive reputation.
Quote:
Good luck
+1
Without watching your video,will do later. I would check your upper ball joints. Just aguess.
Old 07-10-2012, 08:06 PM
Quote:
Please let us know how it works out.
f250 vs 350? --updated---nixed this one... nance459 6.0L Power Stroke Diesel 9 05-06-2015 12:30 PM
2000 F250 Ticking/Knocking Noise F350Man79 1999 to 2016 Super Duty 11 07-28-2014 07:59 PM
Hey Marv, clear May 31st brother!! Stewart_H S. California Chapter 0 04-18-2014 01:36 AM
strange noise coming from 86 bronco ii throttle body mdgaf Bronco II 4 05-24-2013 11:43 AM
knocking noise while in 4x4 2000f1504x4 1999 to 2016 Super Duty 5 12-21-2011 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
