Fuel In Coolant
Old 07-05-2012, 06:18 PM
Brian0445's Avatar
Brian0445
Brian0445 is offline
Fuel In Coolant
This afternoon I discovered that my coolant reservoir was overflowing. I opened the cap an noticed it was over-full with diesel fuel. I removed about a quart of diesel fuel off the top until it looked like just green coolant. Any words of advice where to start to look for a leak? Was planning to pull the motor within the month to replace the oil pain, rear main seal and flywheel/clutch. Oh its a 99 7.3, 260,000miles....Thanks for any input!
Old 07-05-2012, 06:30 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Generally fuel in coolant is due to cracked injector cups. You wouldn't have to pull the motor to replace them, but if you were going to anyway, it would be very easy.
Clay has them in stock, and also has a special tool Riffraff Diesel: Motorcraft 7.3L Injector Cup Kit
Old 07-05-2012, 07:00 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Originally Posted by BigAlsPSD
Generally oil in coolant is due to cracked injector cups. You wouldn't have to pull the motor to replace them, but if you were going to anyway, it would be very easy.
I think you meant Fuel in coolant...
Old 07-05-2012, 07:06 PM
BigAlsPSD's Avatar
BigAlsPSD
Yeah I did, oops.
Old 07-05-2012, 08:03 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
X2 been there done that. Holla at RiffRaff Clay will hook you up. It is no a hard job, just time consuming. When you start the job let us know if you have questions!!
Old 07-06-2012, 05:30 AM
Brian0445's Avatar
Brian0445
Ok thanks for the info! This truck is not a daily driver just a work truck that get used sometimes once a week. I was planning on pulling the motor and doing other work anyways. Thanks again!
Excursion Gary
16
08-22-2020 05:06 PM
Macmathews
01-28-2015 12:58 PM
blieux1
13
08-18-2011 06:15 PM
DieselE
11-18-2009 09:52 AM
jim fowler
09-17-2009 10:39 PM
Quick Reply: Fuel In Coolant
