2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Backup Camera in the Rearview Mirror Question
Old 01-25-2010, 12:09 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
What kind of input does that little LCD screen take?
I'm hoping it's a normal RCA input.
I plan on removing this mirror and installing it into my Mustang. Then installing a backup camera into my Mustang trunklid keyhole. I got my hands on a brand new Taurus auto-dim mirror to replace the Expy one.
camera will be similar to this backup camera on eBay
thx guys
Old 01-27-2010, 07:37 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
I am pretty sure that it is not a standard RCA end. It (the mirror) has a harness that connects to the car. In that harness there should be 3 wires in addition to wires that feed to a non display mirror. These wires should be a video +, video -, and a reverse 12v. The reverse 12volt is what turns on the lcd when the car gets put into reverse.
What you probably have to do is run a wire from the reverse wire in the kick panel to the mirror for power and then cut off the RCA jack to get the outer/inner (+/-) wires and tap those into the mirror harness as well.
There are a lot of shoulds and probablys in my post but I have started doing my homework. I am installing an OEM reverse camera into my 07 expedition which did not come with the wiring for the camera. I am having to run my own wiring because i am going to hook up the camera to the navigation unit and the mirror. I am getting the for sure info on how to wire the mirror, and as soon as i find out I will post again.
Old 01-27-2010, 08:24 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Careful just splitting video cables, you can get a lot of noise that way.
Old 01-27-2010, 09:00 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
radio shack supposedly sells a video cable with a RCA plug on one end and the split wire on the other. I am planning on checking that out sometime soon.
EDIT***Here it is. I bought it today to check it out. http://www.radioshack.com/product/in...uctId=2103849#
<img src=http://grab.by/22O1>
Old 01-29-2010, 03:49 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
thanks guys...I bought my goodies tonight and hopefully will tear into the Expy next week when it all arrives.
I need to re-route the OEM camera harness to the dash for the new head-unit. When I do that, I'm hoping it will simply plug in.
I asked about the RCA plugs though for the integration with the backup camera I am going to buy. the new camera uses a power, ground, and RCA wire.
I need the Expy backup camera mirror to use RCA...but maybe I can use that Radioshack RCA plug thingy.
I have a feeling I'm biting off more than I can chew
Old 07-07-2012, 02:54 PM
rayofsi's Avatar
rayofsi
rayofsi is offline
big bump, just wondering if this was ever figured out. thanks!
Old 07-08-2012, 04:00 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
never ended up doing this mod on the Expy or Mustang
but did a very similar one for my F-250
the factory camera uses 2 wires for video signal. a + and a -. It also has a power wire and a ground.
For my F-250, I grabbed the factory camera and rearview mirror from a 2010 F-150. ran the +/- wires and basically it all just plugged in.
I used rca wires from camera to mirror. It's wired to trigger on when truck is in reverse. The LCD looks awesome and is very functional IMO.
iggy2
1999 to 2016 Super Duty
15
01-02-2020 04:59 AM
Tylus
15
06-01-2017 02:53 AM
tuxedoblackPS
2009 - 2014 F150
04-14-2017 01:03 PM
carid
11-13-2015 08:08 AM
sdetweil
08-15-2010 08:25 PM
Quick Reply: Backup Camera in the Rearview Mirror Question
