Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-05-2012, 05:48 PM
1976Ranger 1976Ranger is offline
Garage is empty, add now
1976Ranger is starting off with a positive reputation.
390 FE airfilter housings?
I just bought the truck and would like to open up the intake airflow a little. It has the factory housing on it now. I thought about putting an open element on it but did not know if the heat would make for too warm of an air charge. Also since the factory housing has the PCV, heat riser coming from the passenger exhaust manifold, etc I did not know how that may work. Ideas or comments?
I also thought about plumbing some ducting from the grill to hook up to the open end on the factory housing. Has anyone got any links or pictures of a homegrown air duct kit attached to the factory housing? Joe Mcgee cold air intake.
  #2 (permalink)
Old 07-06-2012, 12:54 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Lots of vehicles use a duct to get air from outside the engine compartment. You can get the ducting at auto parts stores. Think mid '70s and later, '80s for sure.
While the open element idea seems good, they get dirty quicker due to all the goo thrown at them by the fan, and the PCV needs to function correctly or you will have goo inside the valve covers.
However, there are ways to do the PCV with an open element, and ways to shield the front of the open element. BUT, as you note, no cold air them.
  #3 (permalink)
Old 10-28-2012, 12:33 PM
rikard rikard is offline
1995 Ford F-150
rikard is gaining momentum as a positive member of FTE.
On my old F150 83 302 and a couple of chevys I just went to the JY and picked up an extra snorkel and hose. A few minutes with a hole saw and self tapping screws and I had a dual snorkel system.
regards
rikard
__________________
"Be who you are and say what you feel because those who mind don't matter
and those who matter don't mind."
- Dr. Seuss"
Nelly Belle 1995 Black F150 4x2 SC XLT 300 5 Spd 242k
  #4 (permalink)
Old 01-05-2013, 10:06 AM
vwfreak's Avatar
vwfreak vwfreak is offline
1967 Ford F-250
vwfreak is gaining momentum as a positive member of FTE.vwfreak is gaining momentum as a positive member of FTE.
Quote:
regards
rikard
Got pictures of this?
  #5 (permalink)
Old 01-05-2013, 10:53 AM
1995 Ford F-150
No that was a long time ago in a galaxy far, far, away. At the JY I picked up a spare air cleaner after my original was damaged. After seeing a friends 50s Olds that had the dual snorkel set up I had to have it for my 63 Chevy Bel Air 9CI wagon.
After drilling out the rivets on the snorkel I placed it on the opposite side about 45 deg from the original, marked it and used a hole saw and cut two holes to match the opening of the snorkel. I used sheet metal screws to attach the snorkel. A quick rattle can paint job and I was done. I did this on several other vehicles as it always would get a positive reaction when opening the hood, and I ended up making a couple for friends.
I did the same to my 83 Ford. and connected the extra hose to the opposite side of the radiator.
BTW there was no real increase in performance except on a couple of vans that had real restrictive air intakes. Having dual snorkels with heat stoves did help with cold weather wamups especially on the mid 80s emission carbs.
Happy New Year
rikard.
__________________
- Dr. Seuss"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
