Ignition problem in my 90
Hi, all,
I have a problem with my ignition. The truck will start, but when I release the key into the "run" position, it stops. When I turned the key slowly, I noticed that the gauges will turn on, and then turn off in the middle of the "run" position. They turn back on in the "start" position. So basically, there's a "dead zone" where I have a bad connection. I replaced the key cylinder and nothing changed. Any ideas?
Thanks in advance
Thanks in advance
