Steel Bed Strips
I'll let Ilya (aka 51Panelman) weigh in on this question. Every set of steel strips that I've ever seen had no paint on them...just a rusty finish. If they were painted it didn't last too long since the strips take the brunt of the wear and tear of the bed floor. I also noticed on the steel strips that came out of my F2 that the bottoms were just as rusted as the tops...I'm guessing that Ford used bare steel. I prefer the stainless steel replacements.
Dan
Dan
From what I have found, the bed wood, which would include the strips was painted the color of the truck. I guess that was basically for ease of manufacturing. That left the underside of the wood untreated.
You won't see that approach very often in restorations...just about everybody varnishes the wood if they replace the bed wood...or they leave it plain if they use their truck to haul stuff around.
The old growth wood available in the 50's was tougher than a lot of the wood from farmed trees today. You can still buy old growth lumber, but you'll have to search for it.
Dan
Dan
Thanks Dan - I did locate some old growth log-leaf southern yellow pine - I heard that was the original species.
I saw one truck at the Superntionals in May that had painted boards, I think I will go a little off-original an put an oil finish on mine.
Would you happen to know the original thickness of the boards?
Thanks for you help - I will become a Supporter very soon.
My 49 had a steel floor over some kind of wood that had long dissappeared.
Dan
Dan
My bed wood is red oak with 3 coats of varnish. Next time I paint my truck I want to paint the boards the body color. My question is: how well does auto paint hold up on wood and could I paint right over my varnished boards.
Wood will move no matter what amount of finish or paint you put on it. If you don't mind refinishing it paint will work fine. All sides and edges after all milling of the wood would be best. A good automotive clear coat will help as they have UV inhibitors, but if exposed to weather they will eventually have to be refinished. And Abe, you should strip the varnish off of the wood before applying paint. You might get away with a good sanding for a while, but eventually it will begin to peel.
I have yet to see an original 'oak' bed. AFAIK, all were pine. Ditto the insides of panel trucks, and all beds were painted body color originally including the slats.
I was shopping for a finish coat for my bed at Home Depot and ran into a factory rep from Behr, who supplies much of HD's paints. This guy wasn't a salesman, but a technical rep. I told him what my application was, and he said flat out, there is nothing that will last on a horizontal wood surface that is going to get wet and be outdoors. His advice was to use a finish that can be easily re-applied periodically, like a tung oil or "danish oil". Of course, I ignored his advice and used a marine varnish... It has held up very well, but my truck isn't outdoors much and only gets wet when I wash it, but gets a lot of abrasion from hauling stuff.
An interesting read here, not directly on topic: Model T Ford Forum: Floorboards
