Help! 79 f150 will not crank! - Ford Truck Enthusiasts Forums
Old 07-05-2012, 09:28 AM
HatleyT HatleyT is offline
HatleyT is starting off with a positive reputation.
Ok guys, I have a 79 ford f150-460 big block and I cannot get it to crank at all.. I replaced the ignition coil, starter, starter solenoid, ignition module and Im still not getting any spark to my coil. when I took the dash apartI replaced the ignition switch as well, There is 1 red or orange wire that smokes when the key is turned on, I dont know rather my wireing harness is fried or if maybe just the neutral safety switch is bad.
Old 07-05-2012, 12:22 PM
ChiefM's Avatar
ChiefM ChiefM is offline
ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.
Sounds like you have something wired wrong: check this out and double check your wiring.
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Old 07-05-2012, 12:31 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
SMOKING WIRE!
Sounds like something is creating a ground fault and smoking that wire.
Find and fix the smoking wire problem first.
As for the neutral safety switch.
I would dissconnect it, and put a jumper in it place.
*** MAKE SURE THE TRUCK IS IN PARK, AND TRY CRANKING THE ENGINE. ***
IF that solves your problem, buy a new neutral safety switch.
Old 07-05-2012, 12:51 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
Originally Posted by HatleyT View Post
There is 1 red wire that smokes when the key is turned on.
That's the resistor wire, while it's not the cause of your "no crank" issue it does require immediate attention.
It could be the NSS, test as per 'dynamics' instructions above.
If that fails to resolve the issue TEMPORARILY jumper a lead from +bat to +coil, if the engine starts your problem lies in the solenoid and/or the wire between solenoid and coil.
Old 07-06-2012, 07:26 AM
OK, ive tried hotwiring it from the battery to the coil. It still will only spin over and I checked all the voltage everywhere, the coil is not getting near enough voltage as it needs
Old 07-06-2012, 11:15 AM
Did you replace the resistor wire? the fact it was smoking is a pretty good indication it's fried.
Old 07-06-2012, 11:40 AM
no I havnt replaced the resistor wire yet, I dont know where it leads cause it branches off into different wires, but I did cut it and run a hot wire to both sides, and it only smoked on the side coming from the switch so its the wiring part that connects to the ignition switch i believe
starter, starter solenoid problems sgauvry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-22-2015 06:47 AM
Still can't get this thing running. 79 F350, 351 Cleveland Cbad285 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-21-2015 08:05 PM
1973 F100 starts with remote starter only Lascar 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-27-2015 02:57 PM
Ignition coil problems ved0303 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-02-2015 11:07 PM
1985 F150 F150owns 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 10-15-2006 08:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
