transmission fluid and filter change - Ford Truck Enthusiasts Forums
Old 07-04-2012, 06:58 PM
62star's Avatar
62star 62star is offline
62star is starting off with a positive reputation.
i'm wanting to change my trans fluid and filter on my 2002 explorer xlt. it's starting to hesitate when initally going into gear. it doesn't have the dip stick and the new fluid has to be pumped in through some plugged opening in the side of the trans. what tool do i need to pump the fluid in and what is the procedure for getting the correct fluid level installed.
Old 07-05-2012, 08:40 PM
fordmerc's Avatar
fordmerc fordmerc is offline
fordmerc is starting off with a positive reputation.
Not all of the 5r55 trans can be filled through the trans case. Some have to be filled through the fill plug in the center of the drain plug. I have always filled our mountaineer through the pipe plug in the center of the drain plug.
I have used a fluid pump that looks like a bigger pump that would be on your hand soap bottles etc, with a tube connected to it to pump the fluid through the pipe plug opening.
Last time I did it, I took some advice I have seen on this site and pumped it through using a garden sprayer which worked MUCH better. I just put the fluid in it and had the wife pump it while I held the trigger down.
To make sure I have enough fluid in it, I put 5 quarts in it, then drive it around the block to warm the fluid to temp. Then, while it's running, pull the center pipe plug and see how the fluid comes out. If it doesn't come out at all, you need more fluid. If it comes out in a heavy steam, as if you were draining it, it is over full. If it trickles out or runs out very slow it is full. I have found it takes around 5 to 5.5 quarts.
Hope this helps.
1999 4r100 trans fluid rshep 1999 to 2016 Super Duty 1 02-05-2016 10:19 AM
Question about trans fluid change? svfetter 2007 - 2014 Expedition & Navigator 4 12-28-2015 06:23 PM
Lucas Motormanhbg1 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-11-2012 09:57 PM
Trans Fluid Change buckaroo2219 1987 - 1996 F150 & Larger F-Series Trucks 6 03-27-2011 07:21 PM
Auto. Transmission fluid change or flush? B 3000 Escape & Escape Hybrid 3 02-18-2010 06:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
