05 3 valve 5.4 timing issues
Old 06-27-2013, 09:38 AM
Towster's Avatar
Towster
Towster is offline
Hellllp???!!!!!! Got an f150 05, 5.4 3valve,,,,, over last 12 months replaced both cam phasers, last one just 3 weeks ago, still had noise in engine (tic) heading to work it felt like half of the motor shut off, got quiete but missing badly, would not get out of its own way, towed it to shop, found a broken bolt in driver side lower chain guide walleyed out the oil pump bolt hole, and some wear on cover, replaced oil pump and all guides and chains and tensioners, started up, still missing, unable to determin where the miss is, scan shows left cam advanced and right cam retarded, how do you align the the timing, with out going to dealer????? And what else could it be,,,,, we did check for bent valves, and we seem to get good compression in all holes.
srpservices
2004 - 2008 F150
03-24-2016 07:30 AM
jeffg2500
1999 to 2016 Super Duty
08-21-2015 10:40 AM
Ford'05HG
1997-2006 Expedition & Navigator
02-19-2014 03:37 PM
nw4wheeler
Modular V8 (4.6L, 5.4L)
06-26-2013 07:14 PM
1987LTDmasta
10-29-2011 11:47 AM
Quick Reply: 05 3 valve 5.4 timing issues
