1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Ford Unibody Chop Top
Old 07-04-2012, 02:17 PM
51Super's Avatar
51Super
51Super is offline
I have a chance to pick up a decent 61 SWB Ford Unibody PU hot rod but the top is full of rust and bondo. Thinking about cutting the top off of it and running it topless. I'm thinking with the bed being part of the cab there would be enough structural support in the body to keep the doors aligned, etc. if I add some support in the subframe area. It also currently has a stock leaf spring set-up on the front I-beam axle but someone started to add a R&P set-up that I'm thinking doesn't look too good so I may just go back to stock steering set-up to keep it simple. Anyone have any ideas??
I have a chance to pick up a 61 SWB Ford Unibody PU but the top is full of rust and bondo. Thinking about cutting the top off of it and running it topless. I'm thinking with the bed being part of the cab there would be enough structural support in the body to keep the doors aligned, etc. if I add some support in the subframe area. It currently has a stock leaf spring set-up on the front I-beam axle but someone started to add a R&P set-up that I'm thinking doesn't look too good so I may just go back to stock steering set-up to keep it simple. Anyone have any ideas??
I'm a Ford "Virgin" so be gentle.......
sseebart
Vehicles for Sale
11-10-2015 03:25 PM
cuellar23
04-14-2015 03:42 PM
MarksA-C
25
12-19-2011 10:49 PM
hav24wheel
1947 and Older Ford Trucks
10-13-2011 09:08 PM
Quick Reply: Ford Unibody Chop Top
