Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 07-04-2012, 02:17 PM
51Super 51Super is offline
Garage is empty, add now
51Super is starting off with a positive reputation.
Ford Unibody Chop Top
I have a chance to pick up a decent 61 SWB Ford Unibody PU hot rod but the top is full of rust and bondo. Thinking about cutting the top off of it and running it topless. I'm thinking with the bed being part of the cab there would be enough structural support in the body to keep the doors aligned, etc. if I add some support in the subframe area. It also currently has a stock leaf spring set-up on the front I-beam axle but someone started to add a R&P set-up that I'm thinking doesn't look too good so I may just go back to stock steering set-up to keep it simple. Anyone have any ideas??
I have a chance to pick up a 61 SWB Ford Unibody PU but the top is full of rust and bondo. Thinking about cutting the top off of it and running it topless. I'm thinking with the bed being part of the cab there would be enough structural support in the body to keep the doors aligned, etc. if I add some support in the subframe area. It currently has a stock leaf spring set-up on the front I-beam axle but someone started to add a R&P set-up that I'm thinking doesn't look too good so I may just go back to stock steering set-up to keep it simple. Anyone have any ideas??
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
I'm a Ford "Virgin" so be gentle.......
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
