F-150 2010 fuel pump reset
Should your vehicle shut off after a collision due to this feature, you may
restart your vehicle by doing the following:
1. Turn the ignition switch to the off position.
2. Turn the ignition switch to the on position.
In some instances the vehicle may not restart the first time you try to
restart and may take one additional attempt.restart your vehicle by doing the following:
HTH, Don
So the crew that fixed the body work do not know how to reset the fuel pump?
So did you damage the truck while stealing it and don't know how to get it going?
Sorry, just smelling something that makes no sense. Just stinks.
My 2010 manual says the same thing unfortunately. Didn't there used to be a reset switch behind the kick panel on the pass side? I know there was one in another truck(s) I owned. Does it turn over and just not start? Maybe check the fuel pump relay and fuse, #'s 8 and 27 under the hood in the fuse box on top of the radiator? Post back if you have any new info so we know
Bigdaddy2975
2004 - 2008 F150
07-07-2018 02:21 PM
