STC - Ford Truck Enthusiasts Forums
STC
Old 07-04-2012, 12:30 AM
jhinalabama's Avatar
jhinalabama jhinalabama is offline
jhinalabama is starting off with a positive reputation.
STC
What does STC stand for and where is it located.
Old 07-04-2012, 12:44 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
STC=Snap To Connect
Its a Fitting that attaches the HPOP to the HPO Standpipes
Its on the HPOP they crack and leak usually cause a no start
on the 05+ HPOP
ACRONYMS FORD
http://www.ford-trucks.com/forums/821641-acronyms.html
Old 07-04-2012, 01:39 AM
ok so I would have to pull my HPOP to see them?
Old 07-04-2012, 06:19 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
You have to pull the pump to change the fitting but you can see it with the HPOP cover removed. The '03's and early '04's don't have one.
Updated fitting installed on the HPOP.
STC kit from Ford:
Here is a good video on the procedure:
http://www.youtube.com/watch?v=UuTKD...e_gdata_player
Old 07-04-2012, 09:40 AM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BLADE35 View Post
STC=Snap To Connect
on the 05+ HPOP
ACRONYMS FORD
Blade & Bismic, thank you for this little link. I have been reading things on here for years and just fumbled by or googled it. I am going to add this to my "6.0 File"!
Old 07-04-2012, 09:48 AM
Thanks for all the info
Old 07-04-2012, 01:38 PM
metmop metmop is offline
metmop is gaining momentum as a positive member of FTE.
I just want his torque wrench..... I like the beep.... real handy.... that and it switches between inch-lbs and foot-lbs..... I like....
Old 07-04-2012, 01:43 PM
BLADE35's Avatar
Quote:
Funney you mention that I am turning my computer into a 6.0L closer and closer everyday LOL
I can only imagine all the info mark has
Probably time for me to make a thumb drive copy of all this info I have saved If I had a computer crash I would never recover it all or find some of the info again
Old 07-05-2012, 01:23 AM
berick's Avatar
Quote:
Lol.... I noticed and said the same thing til I thought I could see the "Snapon" writing on the wrench... Then it just turned into an impossible wet dream!
stc g tinsley 6.0L Power Stroke Diesel 5 05-01-2015 09:48 PM
stc fitting g tinsley 6.0L Power Stroke Diesel 1 04-25-2015 03:30 PM
Stc fitting brickie 6.0L Power Stroke Diesel 6 04-21-2014 08:38 AM
Stc fitting waterboy_fishing 6.0L Power Stroke Diesel 33 11-27-2013 10:46 AM
High Pressure Oil bbier64 6.0L Power Stroke Diesel 47 12-04-2012 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
