Hi, i have a 87 6.9 diesel and i have dual tanks and i know alot of times the switcher gets messed up is there anyway to test the tank switcher without running the truck out of fuel?
Not 100% sure how the fuel lines run. If the two tanks fuel lines connect but you could probly pull a line off the tank when it is running to tell which tank fuel is comeing from.
Why do that, when there's a switch marked Front/Rear that tells you that?
From the cab, turn on the key.
Switch tanks and watch the fuel gauge.
If the fuel gauge moves when selecting the other tank the fuel tank selector valve on the frame is working.
If the fuel gauge stays the same the motor is not running in the selector fuel valve.
What if the gauge goes past full and the truck dies?
