Sputtering when I give it gas
Old 07-03-2012, 06:08 PM
Revmitchell's Avatar
Revmitchell
Revmitchell is offline
I have a 92 F-250 4 WD w/the 5.8 liter engine. I have just completed a tuneup but I am still having problems with my engine sputtering when I give it gas. Any thoughts?
Old 07-04-2012, 12:10 AM
Revmitchell
Anyone?......
Old 07-04-2012, 09:53 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Fuel filter? Check the fuel pressure too.
Old 07-04-2012, 08:27 PM
Revmitchell
I did a tune up to include the fuel filter
Old 07-04-2012, 10:16 PM
rla2005's Avatar
rla2005
That leaves my question about fuel pressure.
It's also always a GREAT idea to check for any stored codes. Many times there can be a stored codes or issue that would cause the KOEO tests to fail without having a Check Engine Light on.
One other thought: Do you have dual tanks? Does it happen on both?
Old 07-04-2012, 10:51 PM
burnout400m's Avatar
burnout400m
burnout400m is offline
Did you pull the engine codes? If your truck had dual tanks than see if it does it on both tanks. Did you put on a new coil when you did the tune-up? Does it do it all the time or only when it's warm or cold?
Old 07-04-2012, 11:48 PM
Revmitchell
I did not check the coil. I will do that and I did not check the other tank I will do that as well. Thanks.
Old 07-04-2012, 11:51 PM
burnout400m
Pull the codes too.
Old 07-05-2012, 12:39 AM
Revmitchell
Originally Posted by burnout400m
Pull the codes too.
It will not allow codes to be pulled Readers pick up nothing.
Old 07-05-2012, 12:53 AM
burnout400m
You're not getting ANY codes or you're getting or are you getting the code saying there are no trouble codes?
Old 07-05-2012, 01:13 AM
Revmitchell
I am not getting any codes, after several different readers it refuses to run the test.
Old 07-05-2012, 01:53 AM
GNR22's Avatar
GNR22
GNR22 is online now
Fabri-cobbler
How much can you rev it before it starts sputtering? Does ur truck have a tach? What you're describing sounds like computer problems. I've seen this problem 2 times in the past month and the computers were fried. You could rev it up to about 2200 and it'd cut out and die even slowly revving it. And if you can on it quick it chokes right away. Sound familiar?
Old 07-05-2012, 02:52 AM
andym's Avatar
andym
andym is offline
Not being able to retrieve codes or run diagnostics is a symptom of a bad PCM.
Old 07-05-2012, 03:27 AM
burnout400m
Exactly. Especially with multiple scanners. It should at least throw a code to say that it's not detecting any problems.
Old 07-05-2012, 04:26 AM
norfolknova's Avatar
norfolknova
norfolknova is offline
Have you tried to just ground the single wire that goes to the code reader and get the codes watching the CEL flash. I couldn't get my 92 to give up codes with a code reader but when I ground the single wire it works just fine. Goos like getting it diagnosed
Matt
Quick Reply: Sputtering when I give it gas
