'89 F250 XLT Lariat 4X4 302 CID Manual trans - High Idle issue
Old 07-03-2012, 03:37 PM
Timus's Avatar
Timus
Timus is offline
My truck has been down for a couple of years and am now down to the last couple of issues. The engine will not kick down to a normal Idle speed. If I start it without touching the throttle, it will start and run at around 1200-1500 RPM and then drop down to around 800 RPM when it warms up as it always has. No problem. The issue is that as soon as I throttle it up to move anywhere, it will rev up to 2000 RPM and won't kick down. I originally assumed that the issue was throttle cable or linkage related to it having sat for so long, but, all cables and linkages are free over the full range of motion and work as smoothly as they did when I parked it. Any suggestions?
Old 07-05-2012, 07:59 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Check the TPS signal output and the connector. I had green stuff growing in the connector leading to the TPS. Clean out the corrosion with contact cleaner then apply a little dielectric grease.
The TPS may be compromised as well, but I do not suggest blindly tossing on an inferior aftermarket version. Check yours first after verifying the connector is not gunked up.
bikerbutcher
09-30-2012 02:35 AM
waskin27
05-25-2011 01:41 AM
ForsytheM13
09-12-2010 04:07 PM
Archael
12-03-2004 09:15 PM
Bryan
08-04-1999 12:29 PM
Quick Reply: '89 F250 XLT Lariat 4X4 302 CID Manual trans - High Idle issue
