1994 F250 starting/accelerating problem
Hey all,
just picked up a 94 f250 5.8 liter. Having a few issues with it.. hoping to get some help. First off, it takes about 2 minutes to start it up , with turning the key over and over and over, finally after a while it lights up. Not sure what the issue is there. Once it starts up, it idols perfectly almost. The second issue is when i punch the gas , it kills.. any help is appreciated.
thanks
thanks
Having the same issues. Not at start up, at least it doesn't take 2 minutes, but it takes about 20 seconds of crank and then I turn it off, then turn it on and it usually sputters up. Then when I'm driving, sputters sometimes at start up from a light, stop sign or whatever, or if I'm at a slower speed cruising it will sputter too if I try to speed up.
So I'm interested in fixes. Fuel pump, filter, what? Yes same as op, does it on both tanks. Fuel Filter maybe?
mkl55
06-11-2012 07:33 AM
charliestepp
02-19-2012 06:53 PM
fordinmudd
07-11-2010 02:13 AM
