2004 F150 Lariat Supercrew - Front Shocks
Old 07-03-2012, 10:07 AM
Riskyguy's Avatar
Riskyguy
Riskyguy is offline
This is a 2 wheel drive truck. How difficult is it to change them out? They are inside the coil springs. Should I just replace both the springs and the shocks? Any advice is appreciated!
Old 07-03-2012, 11:18 AM
danorules's Avatar
danorules
danorules is offline
I did the quick struts, spring and shock already built together. The job is fairly easy. Remove the wheel, caliper, rotor, disassemble the top ball joint + steering + sway bar, then you remove the strut. Reinstall in the reverse order, and then get an alignment. Here is the part I used, you will need the one for 2x4 which may be a different part number
https://www.ford-trucks.com/forums/s...ghlight=Monroe
Old 07-03-2012, 01:20 PM
Riskyguy's Avatar
Riskyguy
Riskyguy is offline
Thanks for the response. Did you just buy the assembly locally or find it somewhere on the net?
Old 07-03-2012, 01:25 PM
danorules's Avatar
danorules
I researched the part on the net but bought locally.I work for a local municipality and the garage at work gets killer discounts on parts. Everything gets bought through there now
JBMorrey
11-21-2017 01:54 PM
king-david
06-19-2014 05:31 AM
davbeisner
12-02-2012 12:39 AM
midfel11
11-10-2011 12:52 AM
Quick Reply: 2004 F150 Lariat Supercrew - Front Shocks
