390 4x4 headers??? - Ford Truck Enthusiasts Forums
390 4x4 headers???
Old 07-02-2012, 08:48 PM
FossenRacing's Avatar
FossenRacing FossenRacing is offline
FossenRacing is starting off with a positive reputation.
390 4x4 headers???
any one know of a good set of fe 4x4 headers?
i bought a diy headers but lack the time to build them cause i am by no means a exhaust man.
i want 2 inch primaries into 3.5 collector. if a set that had a primary length of 32-36 inches would be ideal.
Old 07-02-2012, 10:13 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Mad Dog Headers
F-150-350 4WD 1973-79<?XML:NAMESPACE PREFIX = U1 /><U1:P></U1:P>
Part #9228 - 390/428 engine, 2" primarys, 3 " collectors, fenderwell exit.<U1:P></U1:P>
450.00
Old 07-02-2012, 10:25 PM
BlueOvalDismantlers BlueOvalDismantlers is offline
BlueOvalDismantlers is gaining momentum as a positive member of FTE.
I have 2 sets of FE headers, and will be selling a pair cheap if you are interested... PM me
Old 07-03-2012, 10:37 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
You must have alot of motor to be needing 2 inch primaries. I think that most of the headers out there will fit well, especially considering i had a set of cheap flowtechs on my 76 and they fit perfectly
Old 07-03-2012, 05:57 PM
NW 150's Avatar
NW 150 NW 150 is offline
NW 150 is starting off with a positive reputation.
Old 07-03-2012, 06:41 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I bought a set of Sanderson headers (PN FF427) for my 2wd 360FE Bumpside project...3/8-inch flanges at the head and collector and made in the USA . Plain steel for $325 or ceramic coated for much more.
They'll fit a 4x4 too and ya don't have to jack up the engine to install or remove them!
These are ceramic coated:
Old 07-03-2012, 08:12 PM
Quote:
I would say than I have enough motor. Its a stock stroke and bore 390. That's camed to just pull 16 inches of vacuum. (rules)
Head modification is forbidden but port matching the intake to the head is not.
And all the 1 3/4" primary headers have to small of ports for the d2te head. Needs to have a bigger port than the head to prevent reversion.
I just need a good fenderwell header to finally run a collector as there is no room for one inside the frame.
I learned that the hard way when the yoke on the driveshaft smashed the collector and destroyed the driver side header.
Since I am the only one in the club running a fe, I have to have my engine preform at its best.
And my ford builders book is saying to run 2 inch primaries 32 to 36 inches long into a 3.5 inch collector into a pipe that's 18 to 20 inches long and then have a bent dump tip.
And aim it 45 degrees out and it will have a mean rap.
Old 07-03-2012, 08:19 PM
650's Avatar
650 650 is offline
650 is starting off with a positive reputation.
Quote:
Originally Posted by NW 150 View Post
That seems pretty cheap for a set of headers. When you put them on did you have to heat tape wrap the starter to insulate it from the headers?
Old 07-03-2012, 09:12 PM
garthneddy's Avatar
The headers NW 150 posted a link too are the ones i have used as well, they fit great.
Old 07-03-2012, 09:33 PM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
They arent fenderwell exit, correct? Did you have to modify anything to get them to fit?
Old 07-03-2012, 10:10 PM
garthneddy's Avatar
I didnt have to modify a thing when i was running them. It was 100% bolt on
Old 07-04-2012, 08:50 AM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Quote:
Originally Posted by montana_highboy View Post
Mad Dog Headers
450.00
The only fenderwells I'm aware of. Just now getting them installed.
Old 07-04-2012, 09:44 AM
bamaf150's Avatar
Looks like a quality set there Grinner.
Old 07-04-2012, 01:13 PM
74ford4x4 74ford4x4 is offline
74ford4x4 is starting off with a positive reputation.
If you got the money, I get the sandersons or mad dogs cant be the quality and the looks. I put a set of flowtechs and they work and fit pretty good, but they dont look as pretty as sandersons or the mad dogs.
Old 07-11-2012, 07:18 PM
Quote:
called and ordered a set of these last week and called today and mark was just finishing them. hopefully customs doesnt hold them back to long.
have a mud race in 3 weeks and want them on there by then
Stock 360 header size? CJK09 1967 - 1972 F-100 & Larger F-Series Trucks 10 03-15-2016 09:31 PM
For the people running fender well headers oldblue73 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-18-2014 06:52 PM
Mad dog headers question obx 79 shortbed 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-28-2013 03:14 PM
390 upright headers 1977 f-350 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 03-25-2012 08:15 PM
Anyone run Hooker Super Comp R-6832's? johnson2007 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-15-2011 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
