460/T18 clutch rod adjustment...
Old 07-02-2012, 11:49 AM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
I just installed a freshly built 460 mated to a T-18. My problem is when I push the clutch pedal in and try to shift into any gear, I get grinding from the tranny and no engagement. My thinking is that the throwout bearing is not moving in far enough to disengage the pressure plate which I know can be adjusted by using the nuts on the threaded clutch rod. What I don't know and need some light shed on, is if I adjust the clutch rod to apply more pressure on the throwout bearing and in doing so get the travel I need to disengage the pressure plate, won't that keep the throwout bearing on the pressure plate fingers constantly and wear it out prematurely because it is spinning all the time? Also, the clutch would not be engaged 100%. How do I solve this? Thanks
Old 07-02-2012, 03:22 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
First, check you firewall to make sure it's not cracked and flexing, soaking up travel in the system.
Check all pivots etc for slop that also soaks up travel.
Not sure where to send you after that, as if the geometry is right and there is no slop, if it won't disengage then you have to look at whether you have the right parts to start with--which would seem unlikely.
Old 07-03-2012, 10:54 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
^^^ What he says 100%
However if you carry out all those checks and all is good and you then adjust the rod, provided that, after adjustment, you have some free play at the outer end of the throwout lever you are good to go.
candoo
07-21-2015 09:23 AM
tiredolbiker
18
12-20-2012 06:53 PM
Morris98
12-02-2007 07:49 PM
VoltronGundam
03-09-2004 04:18 PM
basmith
08-03-2003 05:08 PM
Quick Reply: 460/T18 clutch rod adjustment...
