Door latch cable - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Door latch cable
Old 07-02-2012, 12:01 PM
Keepitrunnin Keepitrunnin is offline
Keepitrunnin is starting off with a positive reputation.
Door latch cable
'01 F250, extended cab. My rear passenger door wouldn't open. The upper cable broke. Ford now sells assemblies only, cables, handle and upper & lower latches for around $200. Anywhere I can just buy the cable? Besides the cost it's a PIA to remove everything as the existing handle is riveted in. Thanks.
Old 07-03-2012, 01:57 PM
BigBlue99's Avatar
BigBlue99 BigBlue99 is offline
BigBlue99 is starting off with a positive reputation.
I have had the same problem on both of my extended cab doors. I do not know how your cables are broken, but mine had just broken the plastic clips and would not fully actuate the latch. I fixed this with some zip ties but those only lasted about a year. I ended up buying the full latch assemblies and only put in the cables and latches from the new assemblies. I left the rivited handle in the truck to keep from having to drill out the rivits. It only took about half an hour for each side. Job was easy but kind of costly. Hope this helps.
Old 07-15-2013, 09:13 PM
volcom521 volcom521 is offline
volcom521 is starting off with a positive reputation.
I purchased them from a place in South Florida called Mako Hose and Rubber. I had to send them the cable, but it was only $35 for each cable. They shipped out the same day they got it. New cable has brass mounts instead of the junk plastic ones from Ford.
Old 07-15-2013, 11:14 PM
xmontex4's Avatar
xmontex4 xmontex4 is online now
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
I Just recently experienced this only my door would not shut, I'm running into a similar issue as i only need the latch. Would a cable out of an OBS potentially work? I would measure it and search based off the length, maybe you can dig up a non OEM one, it will at least broaden your search so you can get more hits than misses.
Rear door latch Kpl 1997 - 2003 F150 6 09-22-2015 06:46 PM
Rear door latch, super cab. NEW problem??? pwstroker69 1999 - 2003 7.3L Power Stroke Diesel 14 03-17-2015 09:37 AM
1994 F150 - Door Latch Problem 98dad 1987 - 1996 F150 & Larger F-Series Trucks 0 06-04-2014 09:26 PM
92 F150 Inside door handle cable broken mkmchu 1987 - 1996 F150 & Larger F-Series Trucks 2 02-23-2014 02:29 PM
Supercab Upper Latch Fix/Access Ningker 1997 - 2003 F150 4 11-29-2011 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
